Results 1 to 9 of 9
- Feb 2008
- 903
January 21st, 2020 09:07 PM #1Meron po akong tanong regarding sa change of ATF for fortuner 2016::
Sa diagram ng maintenance schedule na nasa manual, ang nakalagay for ATF is I or inspection at 40,000km and also inspection at 80,000km and ang nasa duol ay 24 months. So tanong ko is hindi kailangan palitan ang ATF sa 40k and 80k? Ano yung 24months? Does it mean na on the 24th month, dapat palitan? Usually kase around 24months hindi pa aabot ng 40,000km, mga 20,000km pa seguro...
The same goes to other fluids...
- Jun 2005
- 3,774
January 21st, 2020 09:55 PM #2
- May 2017
- 2,128
- 54,205
- Jun 2005
- 3,774
January 21st, 2020 10:23 PM #5
January 22nd, 2020 12:03 AM #6
Most owner's manuals are confusing.
For hot climate countries like ours and traffic has never gotten any better, changing fluids like the ATF's every 40K kms. is highly recommended.
January 22nd, 2020 12:10 AM #7
- Feb 2008
- 903
February 9th, 2020 09:02 PM #8So I decided that I will have to change the ATF of my 2016 Fortuner A/T Diesel, my question is would it involve only changing the ATF or would it need to remove and clean what is inside the transmission and need to change the gasket? Sorry noob here.... btw, it will be done outside casa
February 9th, 2020 10:45 PM #9
Normal drain and refill will do. A full fluid dialysis can be done but you need a machine for it. You can not just open the whole transmission assembly unless a part needs to be replaced or you need to overhaul the whole assembly.
Very informative discussion guys. Thanks a lot!
Liquid tire sealant
