Results 1 to 10 of 81
- Feb 2008
- 898
February 9th, 2019 10:02 PM #1SMy Innova is with an automatic transmission. This is my dilemma every time mag-traffic sa city and ang ride is usad pagong.... what should I do .... Do I have to maintain at "D" while stepping the brake and release the break to move a little forward? Or could I put it at N with the handbreak then shift back to D and release the handbreak to move forward a little? Stepping on the break for a long period at time hurt my right knee/leg... Ilang estimated seconds or minutes ba before considering placing it at N? Hope someone can enlighten me on this....
- 52,731
February 9th, 2019 10:09 PM #2in crawling traffic, i keep it on D, and press on the brake pedal, releasing it from time to time, to ease the car forward.
when it is total standstill, for longer periods like a minute at least, i put it on N.
kanya-kanyang style po yan.
there are arguments for and against, but my personal bottom line is, "the degree of wear and tear is probably not worth the effort at arguing".
February 9th, 2019 10:18 PM #3
keep proper distance. press brake pedal slowly and release once moving. the tcm and ecu knows what to do naman.
February 10th, 2019 10:41 PM #4
Just keep it in D and press and release the brake pedal as necessary. Do not play with it (shifting from D to N to D) as that will prematurely wear out the transmission friction bands and solenoids. It is an automatic transmission controlled by a computer so leaving it alone works best all the time.
- Oct 2012
- 4,851
February 11th, 2019 12:21 AM #5Mine, i put the gear on N if on heavy traffic and shift to D once its moving... same with traffic light if more than 60secs i put it on N... i dont know if its the right way though... hahaha
February 11th, 2019 07:24 AM #6
Kung hirap na ang legs mo after pressing your brake eh di ipahinga mo na by using N and handbrake
There is what you call muscle fatigue and it varies with every individual. When those legs feel weary pressing the brake pedal its only logical to rest it by engaging the N gear and handbrake..its that simple
Sent from my SM-G532G using Tapatalk
February 11th, 2019 07:35 AM #7
There's no right or wrong, just do kung saan ka comfortable.
February 11th, 2019 07:35 AM #8
Sanayan Lang Yan TS, ilagay mo sa D at apak brake. Dika pala pwde sa mga heavy traffic Yung tipong kalahating araw usad pagong. Tip lang wag ka pupunta NG tagaytay kapag pasko, 7hours aabutin mo sa traffic pababa lang NG santa rosa
- Nov 2017
- 170
February 11th, 2019 07:36 AM #9
- Nov 2009
- 3,484
February 11th, 2019 09:19 AM #10Forget the existence of your left foot to avoid SUA and...
Don't forget to use the right foot to step on the brakes when you need to decelerate/stop the car.
high idle RPM at engine start
