Results 1 to 11 of 11
    Ok lang ba na gamitin ang engine oil sa transmission?
    Aug 2006
    iba and tranny oil.. mas malapot
    Nov 2007
    don't mix the oils...engine is for engine and transmission for transmission...you don't want to damage your ride am I right?
    Quote Originally Posted by ans_lim168 View Post
    Just a background on the question.
    May weird kasi na ingay sa tranny ko. I came across a thread na ang topic similar sa problem ko. To make the story short, yung naging solution nung nag-post ng thread sa problem niya ay nilagyan niya ng engine oil yung tranny. He does not recommend it though. Experiment lang niya but he said it worked.
    I posted this thread baka kasi may iba pa na sumubok na ng ganito.
    Feb 2009
    Actually for my Honda Civic 2003 model, the required oil for the transmission is any SJ rated engine motor oil. I did not believe it at first but it's true. Even a Service Advisor of Honda verified this. Nasa car manual din pala ito. By the way, Manual Transmission ang car ko. Suggest you check your car manual to be sure.
    AFAIK the viscosity for tranny oil is starting around 75w-90. ganyan yung gear max ng Royal Purple.
    Quote Originally Posted by nplazaro View Post
    +1 on this. this is also the recommendation i got from honda gurus when i decided to have my tranny oil flushed a year or 2 ago
    Bro, puwede malaman kung ano brand ng engine oil na ginamit sa transmission ng civic mo at kung ano ang viscosity?
Engine oil for the tranny
