mga sir,.tuwing kelan ba dapat ngcchange ng gear oil?
ok lang ba every after 3 motor oil change?
salamat mga sir![]()
yes normally thousand kilometers yan. if the manual says 40K you can replace it by 30K or earlier.
The average car will never need to change gear oil. However if you do a lot of towing, or carry excessive loads. Its recomended every 50,000 miles to keep it in good shape. If you do heavy pulling probably every 25,000 miles.
Toyota Quezon Ave changed the gear oil on my Avanza at 20,000 kms. Car was 2 years old.
every 40k is ok using decent quality gear oil. if you use monograde or not so good quality gear oil it should be sooner.
