Page 16 of 17 FirstFirst ... 6121314151617 LastLast
Results 301 to 320 of 327
    Feb 2011
    #301
    Quote Originally Posted by bryanf View Post
    Buti nabasa ko tong old thread na to. Planning kase ako to buy 2nd hand Idsi city.
    some of my questions:
    1. Yung jerking issue po ba sa automatic/cvt models lng nangyayari? Pag manual transmission ba walang ganito?
    2. How about sa Vtec model?
    Thanks in advance
    I'd stay away from the CVT of this model. I sold my 2004 iDSI City because of the problematic CVT tranny. Starting 2008, it was no longer bearable because of the frequent jerks and I was advised by the CASA that it'll completely breakdown soon. While it was maintained by the CASA and they used the correct ATF, the frequency in changing the ATF also matters. Di pa kasi uso yung maintenance using months.. mileage lang yung basis and it takes me more than 9mos to reach 5k intervals. Btw, a brand new CVT transmission will cost 300k. I sold the car immediately for 200k in 2010.
    Nov 2011
    #302
    Quote Originally Posted by pobre24 View Post
    The CVT broke because you are using ATF in it.
    Mar 2015
    #303
    while some folks call this the cockroach (ipis) model, i actually find it cute. it reminds me of the jetsons.
    until today, i am still confused at why the AT (actually, CVT) issue occured. manufacturer says it was because owner used the wrong fluid and/or the wrong pms intervals, while owner says the thing's design was flawed...
    MT models are ok. they have no transmission issues.
    i do not know if these models have vtec. but for ordinary daily use, i do not feel non-vtec-ness is an issue.
    Thanks. I have seen some 2008 models with vtec engines 1.5L. Anyway I'm planning to buy the manual transmission...
    #304
    From what i heard this was a design issue. That is why Honda went back to a typical torque converter automatic on the next generation. (GE, GM)
    Of course Honda will never admit this. Hehehe. But it seems they have sorted out the issue because the current generation is now back on CVT.
    #305
    Thanks in advance
    The 2nd gen Honda City idsi uses the 1.3L engine, while the VTEc engine model uses the 1.5L but both uses the same CVT transmission and hence both have the same common jerking problem if it appears.
    if the owner is meticulous in maintaining the car then the jerking might not appear, Honda mechanics suggested replacing the CVT fluid every 20tkm instead of manual booklets recommended 40tkm. always be sure to do a flushing and cleaning of the CVT every 20tkm.
    the M/T model of this unit is a better option, less costly maintenance.
    Mar 2018
    #306
    Ang ikli ng interval ha? Could this be due to the quality of the Honda CVT oil? Thermal breakdown related kaya?
    #307
    Not sure about the quality or thermal breakdown, but sabi sa akin due to the heavy traffic and stop and go daw.
    umabot naman yung honda jazz CVT ko ng almost 100tkm without any major jerking problems.
    Mar 2018
    #308
    Due to wear and tear na I think . . .
    #309
    we'd hardly think honda will admit to poor product engineering and/or design, when it has another "plausible" explanation.
    i think the caveat is, "if the product has an history of issues, it is prudent to stay away from it".
    Sep 2018
    #310
    Quote Originally Posted by suysuy View Post
    Lets share infos in this thread. I have this problem in my 2006 Honda City. It's jerking when the speed is below 30kph-40kph
    When i let go of the gas pedal between these speeds, the rpm will suddenly drop to almost 0rpm! Nanginginig nga ang makina eh. It's like parang manual na nakukulangan ng gas at parang namamatay.
    Isa pang problema ko is when you release the gas pedal at any speed, ang bilis mag decelerate parang naka engine brake although the rpm stays at 1k. And i can hear a whistling noise.
    22k pa ang mileage ko. Never pa na replace ang CVT-F
    what should i do mga pare? Replace muna CVT-F? I've tried resetting the CVT. I did the reset procedures but still no avail.
    Sino pa ba dito nagkakaproblema sa kanilang CVT? Hindi ganito transmission ko dati. Ngayong lang lumabas ang mga anomalya.
    Yung jazz gd ko naman is jeking ang na experience ko, so nagpalit ako ng 8spark plug at 4ignition coil sa likod. Tapos sa transmission naman pag nagreverae ka specially pag buhay ang AC nanginginig ang makina. So what should I do
    Sep 2018
    #311
    Hi Sirs,, help po..
    may solution na po ba yung jerking problem and rpm drop sa Honda GD Jazz/Fit??
    Quote Originally Posted by Gieric View Post
    Hi Sirs,, help po..
    rpm drop.. it is most likely the ignition coils
    May 2019
    #313
    Jul 2017
    #314
    ilang liters po kelangan kung magpapalit ng cvtf sa Honda city
    Sent from my RNE-L22 using Tapatalk
    #315
    sorry buhayin ko lang uli. time for CVT fluid change yun 2009 jazz gd 1.5 vtec ni pinsan. awa ng panahon ok pa yun cvt 136000 kms. ask ko lang ang tamang fluid CVT-F ba or HCF2? wala kasi nang manual nun binili
    also consensus sana would you be comfortable using hyundai xteer cvt rated HCF2/z1 if it were your own car? tiwala naman ako sa xteer sa cvt hindi hehe.
    genuine honda hcf is 2.5k hyundai xteer is 1.5k eh medyo penny pinching din.
    thanks sa sasagot.
    thanks sa sasagot.
    it meets gen2 (current)
    and gen1 honda cvt fluid requirements...
    use correct amount...
    #317
    thanks sa sasagot.
    Confused. Wasn't the 2009 a GE Jazz w/ A/T, not CVT?[emoji848]
    #318
    thank you. will most probably use this.
    #319
    had to look it up sa picture pa. definitely cvt so you are correct not a 2009 model. 2006 ata. sorry for the brain farct there.
    #320
    [emoji106]
Honda Jazz/City CVT Problems. Anyone?
