Results 1 to 5 of 5
    Dec 2008
    Hi guys,
    Hihingi lang po ng konting tulong. Honda CRV 1998 ko po nag iingay pag nagsisimula umandar from a cold engine. I guess sa transmission po ito, kasi sa ilalim ng makina nanggagaling. Parang bakal sa bakal na nag ciclick ang sound, and it continues as i accelerate. Pero napansin ko, after around 15-30 minutes of continuous drive, nawawala siya. Baka lubrication lang or something. Pero Im not so sure. By the way, kakadagdag ko lang ng Honda ATF din and nasa tamang level na siya pero ganun parin.
    Ano po kaya ito? salamat ng marami.
    Apr 2004
    could be piston slap.
    or a stuck valve lifter. ano oil gamit mo? switch to 10w-40.
    or dirty throttle body.
    Dec 2008
    Quote Originally Posted by voltscastillo View Post
    Sakto sir. I use 10w-40. And kaka change oil ko lang din last weekend.
    Dec 2008
    And kung piston slap or sa throttle body, hindi po ba dapat under the hood yung ingay? correct me if im wrong. Sa ilalim po mismo ng car nanggagaling yung noise.
    Quote Originally Posted by earlsantos View Post
    Hi guys,
    Why not bring it to the service shop so a qualified mechanic can check it out sooner than later?
    If it's a serious problem, you might avoid costly repairs if a check was done earlier than later.
Honda CRV Noisy transmission
