Results 1 to 8 of 8
- Aug 2007
- 42
July 10th, 2010 03:39 PM #1Mga bossing ganito po kasi yan. pinaayos ko kotse for leaks and pagbalik sa akin napansin ko na when i do a full stop from a normal drive ayaw na kumagat and D4 or D3 pero sa d2 ok sya. Meron din po syang reverse. Ano po kaya naging problem nito. Hindi naman po ginalaw ang transmission nya pero ang nakita ko po ay tinanggal ang clutch pack or something. May mali po ba sa pagkabit kaya ganito?
Automatic po pala ang tranny ko.
Help naman po.
July 12th, 2010 07:07 AM #2
paki claro lang po, hindi ginalaw ang transmission pero tinanggal ang clutch pack?????
- Aug 2007
- 42
July 12th, 2010 09:12 AM #3
July 12th, 2010 01:19 PM #4
clutch pack is inside in the automatic transmission, or you maybe referring to other component/parts not the clutch pack. hindi kaya torque converter ang sinasabi mo?
- Aug 2007
- 42
July 12th, 2010 08:39 PM #5
- Aug 2007
- 42
July 13th, 2010 03:48 PM #8
maganda siguro pa scan mo ang transmission mo. or icheck mo mga electrical connectors ng transmission solenoids mo bka lumuwag or hindi naikbalik ng maayos. mayron naman procedure to manually diagnose transmission codes by grounding the check connector and counting the blinks ng D sa instrument panel. or try resetting the tcm by disconnecting the back-up fuse.
Traffic!
