Results 1 to 10 of 20
- Jan 2005
- 445
February 1st, 2010 07:08 PM #1Ung Brother ko may CRV AT 90's model, Problem nya nung una, ang tagal magshift umaabot ng 40kms per hr bago mag shift ng segunda. Nilinis ng mekaniko ung tranny tapos pinalitan ung fluids. Nag shift na sya ng ayos pag malamig, pag uminit kahit 1st gear parang nagslip ayaw umandar. Help please.
- Nov 2009
- 456
February 2nd, 2010 08:10 AM #2Where and who fixed the transmission? Did they use the correct transmission oil as indicated in the owner's manual? Using an incorrect A/T fluid may affect shifting patterns and may damage the transmission.
February 2nd, 2010 08:36 AM #3
Pre
in my experience using AT, usually the whole mechanism will start to worn out after 7-10 years depending on the usage. I had mine checked,analyzed,repaired and modified at Lucas autotrans (service road area -turn right before forth bonifacio coming from villamor/nichols.) They specialize autotrans local and imported cars, parts are all imported.
- Jan 2005
- 445
February 2nd, 2010 02:16 PM #4Thanks for the reply guys, matagal na rin sila gumagawa ng at pero mga toyota ang gawa nila.
t3kk3n,
How much ang ginastos mo?
February 2nd, 2010 11:08 PM #5
*reym
depende sa tranny parts mo, initial cost was at 30k (2nd and 3rd gear burnout, they will replace all worn out parts, but still after a few years same issue again (1st and 4th gear). they offer me another option, replace the entire internal assembly parts and modify a particular part inside the tranny (60k) but this will improve the shifting (less jerking when shifting). (lancer GLXi). the other car was an accord, cost is at around 80k (due to the transmission is bigAll parts was ordered in the US it took 3-4 weeks for the car to be fixed but it was worth it
- Jan 2005
- 445
February 12th, 2010 12:02 PM #6Hi Guys,
It turns out that the fault was the linear solonoid w/c is the component of the Honda A/T.
Thanks a lot guys.
- Apr 2020
- 16
November 9th, 2020 03:19 PM #7Hi Guys,
I recently bought a 2007 Honda CRV 2.0 engine. Problem is kapag nag shishift from N to D may jerking na nangyayari meron din jerking when shifting to R pero mahina lang. Kapag hinataw naman smooth na smooth yung takbo. Pinalitan ko ATF recently pero hindi padin nawala. Honda DW1 yung ginamit ko na ATF. Baka may naka experience na ng same problem.
- Apr 2020
- 16
November 9th, 2020 03:32 PM #8Hi Guys,
November 9th, 2020 04:01 PM #9
- Apr 2020
- 16
November 9th, 2020 04:04 PM #10
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
