Results 1 to 4 of 4
- May 2008
- 35
October 28th, 2009 10:26 PM #1Guys! ano ba recommended gear oil for chevy spark? According sa owners manual 75w/85w without indicating kung GL1 or GL4 or iba... Nag pa 40k PMS ako at pinalitan yung gear oil, napansin ko SAE90 GL1 ang ipinalit... now i'm having a problem everytime na bagong start ang car.... hard shifting sya ng first gear and second gear but after few kilometers nagiging smooth naman pero unlike before bago mag palit ng gear oil, mas smooth talaga ang shifting.... I think gear oil ang prob so gusto ko pong palitan kahit DIY nalang. Thanks!
Drive safe!
October 28th, 2009 10:54 PM #2
kapag sobra ang gear oil tumitigas talaga ang kambyo.
mobil molilube is a 80w-90 gl5 gear oil. i use it on all my vehicles. ok naman sya.
- May 2008
- 35
October 29th, 2009 10:07 PM #3
Thanks sir, pero may na search ako na may transmissions na di compatible sa GL5 gear oil kasi it contain high EP (extreme pressure) which is corrosive to some other parts, paki correct nalang po if mali.... yung sa exalta namin naka indicate na GL4 ang recommended pero sa spark namin walang nakalagay....
If sobra yung gear oil, yun po ang kailangan kong icheck.... may chevy/Gm Daewoo car din po ba kayo? thanks uli.
Drive Safe!
October 29th, 2009 10:53 PM #4
corolla and sentra ang pinaggagamitan ko nung gear oil na yun at wala naman akong naging problema sa tagal ko ng ginagamit yun
dati kasi nung 1st time ko magpachange gear oil sa isang gas station hinintay mapuno ng mekaniko mapuno ng gear oil yung transmission. ayun kinabukasan ang tigas ng kambyo. kaya diy na lang ako parati para sakto.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
