Results 1 to 18 of 18
    Dec 2007
    HELP!!! i have a toyota land cruiser full time 4WD.pinagawa ko AT kasi weak sa reverse at ang 3rd gear or overdrive is late mag shift.sbi ng mngagawa is need to be rebuild.then after ma rebuild or overhaul nawala Drive 2nd and 3rd gear.pero lumakas reverse nya.low gear lang nagana and pag nag shift sa 2nd gear parang nag eengine break..sbi nya bili na lang daw kami ng surplus na matic...anu po mga oppinion nyo regarding my case.may na miss ba sa pag rerebuild??? almost nka 4 na babana transmission.and wala pa rin direction..
    Nov 2007
    boss malinis po ba sa pinagawaan ng land cruiser nyo?
    Jun 2007
    backjob yan! mukang dinurog LC niyo ha, kung bili ka ng surplus tranny pakabit niyo free na pwedeng pasok sa backjob yan bayad na kayo e wala naman nangyari
    Dec 2007
    anu po ang point.why nyo tanung kung malinis ung pagawaan? nag karoon ako ng idea'' d kaya sa valve body sa main solenoid ang problem??? anu sa tingin nyo???
    Sorry to say, AT are NOT easily repairable, not even in AT-heavy countries like the US do they recommend AT refurbishing as the hydraulic nature of AT systems are really, really complex and a slight variance in hydraulic pressure within its hundreds of chambers are next to impossible to do it right. Even if there are shops that can do it, the cost in the US for refurbishing AT will probably be not worth it.
    Dec 2007
    Quote Originally Posted by theveed View Post
    sir, sorry pero may simpleng correction lang po. dito sa US kayang kaya i-rebuilt ang mga AT transmissions (American, Japanese and European) kaya sobrang dami ng mga Transmission Shops dito. Transmission shops out here that can re-build AT & MT trannies. and they re-built it within factory specs, kaya minsan you cant even tell if its re-built or not. ika nga dito sa US, para ka naring Doctor pag mahusay kang mag re-build ng Transmissions (Auto or Manual).. thats why Tranny re-builds dont come cheap. usually it costs $1200-$1800 for a "BASIC" re-build. high performance re-build costs $2,000-$3,000 (or more) parts & labor only.
    anywayz, back to the topic. malamang masama ang pag gawa ng transmission ng Land Cruiser. I would suggest getting a surplus tranny (thats if wala talagang mahusay na tranny shops in your area) and have them install it for free.. with labor warranty!
    aite, peace.
    Jul 2006
    The difference between the mechanics there and in the US is here in the US the information is readily accessible, while there it takes some research to find the right information. Training is another matter too! And if you took the car to a shop that is not specialized to your particular needs, mahihirapan lang sila and they will simply do guess work. If you take it to a shop that knows the insides of your car mechanicals, mabilis lang yan and you'll save on labor due to the experience and knowledge, plus mahusay pagkagawa.
    Take it to a recommended shop. Somebody will mention reputable shops here that can handle that job. Di lang basta basta saan dinadala yan. Land Cruiser pa!
    Dec 2007
    anu po sa tingin nyo??? susuko sa lng ako sa transmission ko??? and paltan na lng surplus???
    Dec 2007
    Quote Originally Posted by jamalcantos View Post
    sir padala niyo dito sa California yung tranny niyo at may kilala akong pwede mag rebuild niyan! JK!! hehehe
    anywayz, in your situation mas mabuti na mag maghanap na kayo ng mas reputable na surplus transmission shops. then ipakabit niyo nalang sa ibang shop. kung tiga Pilipinas lang ako sir, tinulungan na kita!
    aite, peace.
    Nov 2007
    maselang kasi ang automatic transmision pag madumi ang pinag gawaan
    boss back job yan kasi nung pinagawa namin yng automatic transmision ng kia pregio namin ayus naman eh
    Dec 2007
    Maraming pong salamat sa mga reply nyo..nakakalungkot ang nagyari sakin gastos ako ng gastos.wala namang nangyayari...
    Quote Originally Posted by KBR View Post
    aite, peace.
    I agree, allow me to rephrase, then... Even with the abundance of AT repair shops in the US, repairing ATs are costly expenses and unless your car still has relative value after the repair, most will opt not to get it repaired... If you drive a 2nd hand car that has a residual value of around 3-5K left, medyo pointless na to repair din.
    Anyway, back to the LC, surplus may be the better solution, i sincerely doubt there are any shops in the Phil that'll do things the right way with AT repair as it requires substantial hardware investment...
    Mbeige summed it up well, it'll merely be "guesswork"...
    Dec 2007
    Pa convert ko na lang po kaya sa manual ung landcruiser???bka malasin ulit nman ako sa surplus at di din mag tagal ung surplus na binili ko,anu po kayahelp me deside...
    Nov 2007
    mahirap n pag isipan bro pero mas maganda wag na dun sa dati mong mekaniko ipagawa
    Nov 2003
    that's stupid advice. sana kung di nila kaya gawin in the 1st place di ka na pinagastos and bumili ka na ng surplus tranny in the 1st place.
    Dec 2007
    Sir speedyfix.nkakapag convert po ba kyo ng matic into manual tranny??? magknu po estimate ng ganun???
    Migs (Happy NY BTW bro), kung tama abiso nila right from the start, di nila pagkakakitaan yung biktima hehe
    Nov 2003
    jamalcantos, we can provide the labor pero i do not have suppliers for the MT parts. sorry!
    theveed, hehehe! tama ka dun bro happy new year din!!!
Help !!! Rebuild  automatic transmission
