Konting tulong lang po.
I recently changed my clutch master cylinder. DIY lang.
What I did is after the installation, connect the hydraulic lines, checked to see of the bleeder screw on the slave cylinder is closed, poured dot3 fluid on the reservoir, pumped the clutch pedal, release the pedal, open the slave cylinder bleeder valve.
After a few tries, still no pressure on the clutch pedal, malambot pa rin, pwedeng itulak ng kamay without effort.
How do we bleed it? ako lang kasi mag isa. wala akong mahanap na katulong mag bleed. after 2 days pa darating mga makaktulong sakin dito.
-kelangan ba naka depress ang clutch pedal before loosening the bleeder screw sa slave cylinder?
-few pumps (like 10 pumps) ba muna kelangan then depress then loosen the bleeder screw or depress the clutch pedal, then loosen the bleeder screw?
Ubos na 500ml ng brake fluid ko. di pa rin nagana clutch ko. bibili pa ulit ako mamaya.
Konting advice lang po.
Thanks
