Last week, I brought our Carnival 2001 to the casa for a check-up, oil change, and brake pad replacements....
Upon checking-up, the recommendations came and the scope of work were:
Change Oil, Change Oil Filter, Change Brake Pads, Change Alternator and Aircon Belts, Adjust Parking Brake, Adjust Steering Wheel to Center and Clean Intake Manifold.
The work was finished past 7pm. While driving on my way home, I noticed the steering became hard when turning and may kabig pa sa kanan PLUS when the shifter is at P and shifted downwards to R/N/D ang tigas as if something is going to break, then kung mailipat man sa ibang gear, lalagutok muna.... and while its at D, the shifter can be moved upward and downwards (mukhang maluwag).....
These were not noticed prior to the check-up.
I got back the following day, the Steering was fixed but the Shifter was the same. Apparently, there was no violation of the Transmission with regards to the work done. The Service Advisor said it seems to be that the Transmission Cable is tight and needs to be adjusted.
Any comments and suggestions would be GREATLY appreciated.
THANKS!!!!
