Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    I used to drive a car with a cable type clutch. adjustment seems so easy and simple without major fix.
    I want to ask if hydraulic clutch is also adjustable and how is it done?
    car is a pajero generation 1
    4d56 td, fmic.
    tia!
    Feb 2009
    Quote Originally Posted by rendevone View Post
    4d56 td, fmic.
    tia!
    hydraulic clutch release is not adjustable. the hydraulic system adjusts itself much like the hydraulic lifters for your intake and exhaust valves that maintain zero lash.
    Jul 2010
    Check under the clutch pedal of your pajero. In our lancer there is a adjustment on the clutch pedal where you can adjust the rod that is pushing on the clutch master. HTH
    thanks sir!
    since shifting is hard to engage, what is the remedy then?
    I do double pump on the pedal, not sufficient though.
    Feb 2009
    thanks sir!
    difficulty in gear engagement is usually caused by misadjustment on the linkage or cable for non hydraulic clutch release systems. since you have a hydraulic system, the cause might be low on gear oil or the friction plate is either worn out or contaminated with oil. sometimes the difficulty of engagement into gear can be caused by worn out synchronizers. unless you are talking about increased effort to release the clutch, the cause could be binding linkage or clutch pedal arm.
    Jul 2011
    hi good day, mayroon din po akong problem sa aking kia pregio.. kadalasan parang stuck up yung kambyo kahit naka-fully depress na yung clutch. naeexperience ko ito kapag naka primera at kung aatras ako.
    ang senaryo ganito lalo na kapag magpapark, tapak sa clutch then kambyo sa primera pero once na hindi mo nirelease ang pagkakatapak sa clucth eh mahirap at stuck up kung kakambyo mo pa neutral or paatras so walang ibang choice kundi patayin ang makina. ganun din kung aatras.
    so ang ginagawa ko..konting move/andar dapat release agad ng clucth tapos saka magkambyo na lng ulit. kung baga hindi pwedeng nakababad yung tapak ng clucth.
    worst nito kapag trapik at medyo pataas yung daan..
    need help here..TIA
    Feb 2009
    Quote Originally Posted by gtamp View Post
    need help here..TIA
    first, start with the basic. change your transmission oil and take specimen of the drained used gear oil. use the recommended oil for the average ambient temperature where the truck is going to be used.
    Jul 2011
    same lang ba yung transmission oil sa gear oil?
    Feb 2009
    for your rig, you need extreme pressure (EP), hypoid gear 85W140, GL 4/5 whichever of the gear oil you have in the owner's manual.
    Jul 2003
    double pump normally works only for the hydraulic brake system.
    Jul 2011
    sa owners manual ng pregio ko nakalagay transmission oil SAE 75W-90 so oks lang kung gagamit ng 85W140?
    anu anu po locally available na brand w/ rating na 85W140
    Feb 2009
    try to find 75w90 with due diligence or check your owner's manual which viscosity is best suited for the philippine average ambient temperature
    Jul 2011
    yung pregio ko po ay dito nabili sa pinas...
    Jun 2011
    gear oil and trans oil magka iba po yan,,
    Jun 2011
    magka iba po yan sir gear oil at trans oil
    May 2009
    Quote Originally Posted by mikehunter1980 View Post
    ano pinagkaiba?
    Jul 2003
    using the wrong type of or rating of transmission oil can cause damage to the gear synchronizers in the long run.
    Jul 2011
    oks lang ba kung synthetic? 2004 model yung pregio ko?
    Feb 2009
    as long as it meets the minimum requirements set by SAE and API. it should be listed in your owner's manual
    Jul 2011
    as per service manual under manual transmission
    API Service class GL4
    Four seasons; SAE 75W-90
hydraulic clutch adjustment
