Results 1 to 15 of 15
    I recently saw unused Petron Gear Oil in our bodega. it says "recommended for manual transmission" didn't mention Auto Transmission.
    can I use it in our A/T Differential Gear Oil?
    it also says available in sae90 and sae140. are there thinner than 90?
    first change oil attempt after 177t km...
    no it cannot be used on auto tranny.
    Jul 2006
    Quote Originally Posted by rion View Post
    look for the oil specifications for A/T in your manual. pag A/T transmission usually DEXRON II or III, MERCON, etc ang ginagamit. baka masira lang A/T tyranny mo if you used that kind of oil. A/T tyranny has more complicated mechanical parts compared to a manual one. and sae90 and sae140 are commonly used for manual transmission only. there's a special oil called ATF that must be used exclusively for A/T.
    Quote Originally Posted by 2Dmax View Post
    oh no, I'm reffering to Differential Gear Oils.
    and are there multigrade Differential Gear Oil sold localy like 75w90?
    pede siguro yan sir rion.. since its a gear oil.. ano ba rating
    ang pagkakaalam ko sa multigrade yung "w" don is a winter rating or cold rating.. since hindi naman nag snow sa pinas ok lang straight yung grade nung oil... correct me if im wrong tsikoteers...
    Jun 2006
    No AT use ATF. Don't put differential oil in it!
    As stated earlier by 2Dmax, it usually Dexron or Mercon. Mercon is used by Ford. Dexron III is almost univeral as it is used by most (not all) other car manufacturers.
    Still, check your manual on what is the correct fluid to use.
    let me get this straight... sir rion san mo ba gagamitin? sa trans ba o sa differential? these are two different components of the vehicle
    kse kung sa trans nde pede.. kung sa differential palagay ko pede yan
Gear Oil for Auto Tranny
