Greetings fellow tsikoteers! I have a problem regarding clutch fluid leak. Sinilip ko sa loob(driver's side) above the clutch pedal, merong tumatagas na clutch fluid pero mahina lang, that explains kung bakit palagi nababawasan ang fluid sa reservoir. My uncle said i should by a repair kit for that. madali lang ba ayusin ito and san ko pwede ipagawa? san nakakabili ng ganitong repair kit(tama ba na repair kit ang tawag) pls help. By the way, car is ae92. Thanks in advance.
yup...palit na agad yan...mahirap malusutan ng clutch while on the road...already happened to me 2x! first was while on a site visit (whew!), 2nd, i had to be towed (damn towtrucks, napamahal tuloy ako). ngayon, may leak or wala, i replace at least every 1.5 to 2 years as preventive.
Pre, take my advice .. bilihin mo na yon buong assembly kay sa yon repair kit lng kasi bibigay agad yan, baka masiran ka pa sa daan. Parehas tyo ng problem ko noon my tagas sa loob pero kunti lng, ibig sabihin sira na yon goma sa loob ng barel. Pre, take my advice .. bilihin mo na yon buong assembly kay sa yon repair kit lng kasi bibigay agad yan, baka masiran ka pa sa daan. Kc nagyari na sakin yan pag-gawa ako twice repair kit lng bigay after a week, buti n lng lagi sa parking lot ako nasiraaan.
hello again mga tsongs! buhayin ko ulit itong thread bec bumalik na naman yung leak sa primary clutch ko. Last april 2006 ako nagpalit ng clutch repair kit. wala pang one year nag leak ulit. Im planning to buy a replacement clutch master assembly nalang instead of a repair kit... Would appreciate your inputs. Should i buy abother repair kit or whole clutch assembly nalang? kung sakali man, ok ba ang replacement clutch assembly? Thanks in advance.
Ganyan dati yung kaibigan ko lagi siya nasisiraan at nagpapalit nang repair kit kasi walang makuhang bagong master assembly. Nung napalitan nya na ng master hayun ok n kahit surplus lang pinalit nya.
Mas recommended magpalit ng master assembly kesa repair kit para iwas breakdown.
thanks for the tips... i opted to buy the whole clutch master assembly. replacement lang nabili ko worth 850. pina-install ko na and will just observe nalang if the leak will occur again.
