holy crap... nag pa estimate ako sa shop and a whooping 10k!
weeeee... sarap...![]()
take a look guys kung tama ba ginawa nila sa presyo..
car is corolla xe 2e engine (big body).
- down transmission due to leaking oil seals (labor 1,200php)
* parts that are to be possible replacements are clutch pressure, bearing, oil seal, pilot bearing and clutch linya.. * 5,000 php range ng parts (sila na bahala bili sa parts )
- alignment 600 php 4 wheel alignment ( kasi down transmission )
- overhaul steering pump ASSY??? assymble ata yun nka sulat dito (leaking due to busted bearings )
* 1 set kit
[ estimate 10,000php budget ]
[ estimate of work = 1 day dahil madami mechanic / assistant at solid yung shop ]
Shop is Roadstar Corporation.
ano po masabi nyo ok naba to or not? or should I try 2nd opinion. cgurado kasi sila di kagaya daw sa labas lng pagawa.
P.S. pwde daw pa gawa ng bushings sa labas yung solid na rubber.
What do you think guys?![]()
