Results 1 to 8 of 8
    Aug 2005
    holy crap... nag pa estimate ako sa shop and a whooping 10k!
    weeeee... sarap...
    take a look guys kung tama ba ginawa nila sa presyo..
    car is corolla xe 2e engine (big body).
    - down transmission due to leaking oil seals (labor 1,200php)
    * parts that are to be possible replacements are clutch pressure, bearing, oil seal, pilot bearing and clutch linya.. * 5,000 php range ng parts (sila na bahala bili sa parts )
    - alignment 600 php 4 wheel alignment ( kasi down transmission )
    - overhaul steering pump ASSY??? assymble ata yun nka sulat dito (leaking due to busted bearings )
    * 1 set kit
    [ estimate 10,000php budget ]
    [ estimate of work = 1 day dahil madami mechanic / assistant at solid yung shop ]
    Shop is Roadstar Corporation.
    ano po masabi nyo ok naba to or not? or should I try 2nd opinion. cgurado kasi sila di kagaya daw sa labas lng pagawa.
    P.S. pwde daw pa gawa ng bushings sa labas yung solid na rubber.
    What do you think guys?
    Jun 2005
    estimate lang:
    pressure plate and clutch lining: around 3-4k each
    release and pilot bearing: around 1k5 each
    ako kay 4k8 ang pressure plate and clutch lining sa pick-up nako and release bearing was around 1k6 cguro. the corolla is smaller so cheaper gyud ang pressure plate and lining.
    asa nang roadstar corporation? nagcanvass ko ug para PDR...
    Nov 2003
    depends on the parts they will use naman. sounds about right for the work that will be done.
    Aug 2005
    okey... thanx sa nag post.. baka kasi overpricing yung ginawa nila..
    Aug 2005
    weee... 5.5k lng nagastos ko kasi okey na okey pa daw clutch ko eh.. hehehe.. hay may pang shopping na ulit..
    replace my engine support
    overhaul kit for power steering pump
    oil seal replace near transmission
    alingnment
    weeeee...
    tama narin,.. bsta magaling at maayos gumawa, ok na.. kung nagka flaw sa trabaho,.. ibalik mo agad!
    Aug 2005
    okey sir eh.. maganda mag trabaho wlang leak at tama sa tyming.. ty sa mga concerns!
    Jul 2005
    Quote Originally Posted by finchy18
    alingnment
    weeeee...
    bro, san exact address nyan. mukhang masaya ka sa result ah. balak ko din sana.
Down transmission and overhaul steering pump
