Results 1 to 10 of 21
- Dec 2006
- 85
April 17th, 2008 09:55 AM #1mga bossing. i had a problem sa starex 99 A/T ko. bagong engine overhaul po sya. newly change din tranny atf at gear oil. delayed po yung pag shift nya.1-2-3-4 gear.yung 1 to 2nd umaabot ng around 2000 rpm bago mag shift, yung 3rd mga 2,300rpm, yung 4th gear naman mga 2,700rpm sometimes abot pa ng 3,000rpm bago mag shift. naaawa ako sa engine , galit na galit bago mag shift. ano po kaya possible na sira o dapat icheck.?salamat
April 17th, 2008 03:22 PM #3
habol ko lang po bossing baka naka press button yung over drive mo sa shift knob or anything kung san naka lagay sa starex mo?
kasi yung sa pregio namin dati ganyan din e yun pala laging nka eco power drive sya kaya lagi ag oover drive ang transmission
April 17th, 2008 03:37 PM #4
Sa mga A/T na mga sasakyan, ang shifting point ay nagbabago depende kung gaano kalalim ang apak sa gas. So kung agressive ang tapak mo, possible na sa 3,000 RPM or more bago mag shift up.
April 17th, 2008 07:08 PM #5
- Jan 2008
- 4,726
April 17th, 2008 07:39 PM #6
have minor adjustment to the Automatic Transmission Throttle Cable (can be seen on the engine throttle)... normally this cable is adjusted to the lowest setting but if there are delays in shifting..or slight slippage you need to adjust this to compensate.. on normal road and running condition A/T should shift just before reaching 2000rpm, if you step on the gas for more power shifting will be delayed slightly by past 2000rpm or more... adjusting your A/T Throttle Cable will compensate this delay in shifting
- Dec 2006
- 85
April 17th, 2008 09:13 PM #7Thanks guys sa mga inputs nyo. naka unpress po yung OD ng starex when i drive.smooth driving lang po ginagawa ko, sometimes yung 2nd & 3rd gear before mag 2,000 nagshishift na po, pero most of the time lagpas talaga sa 2thou. dati naman po syang smooth shifting lang, i mean hindi galit yung makina bago mag shift. 3 months ko kasi syang hindi nai drive since nagkaron ako ng driver that time hanggang sa nasira na at umabot na sa overhauling ng engine. so tinanggal ko na driver ko, after ma overhaul, eto na nga, pakiramdam ko delayed na yung shifting. kaya last monday nadaanan ko mitsubishi casa, dun ako nagpa change atf at gear oil, hoping magiimprove yung shifting pero ganun pa din.
thanks din sir yapoy for the info, will try to ask sa malapit na mechanic sa amin about that cable. sana adjustment nga lang.
bukod po sa Throttle Cable, may iba pa po ba akong dapat icheck? thanks
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 18th, 2008 05:39 AM #8that's the problem. if the overdrive button is not engaged (meaning overdrive off) then talagang mas mataas rpm bago magshift. try turning the overdrive on para bumaba sya.
- Dec 2006
- 85
April 18th, 2008 08:12 AM #9thanks sa reply speedyfix. is it you miggs? i bought RP dyan sa shop mo, gumanda fuel consumption ng focus ko.
sorry na confuse din ako sa post ko.. i meant naka OD on parati ako mag drive. may possibility ba na synchronisers ang may sira kahit na delayed shifting lang? thanks
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
