Results 1 to 10 of 11
- 5
May 22nd, 2003 07:38 AM #1bigla kasing na drain yung battery ko kanina. eh no choice kundi itulak ng mga mmda sa tabi. ano po ba ang pwedeng masira sa kotse pag tinulak? nilagay ko lang sa N ang gear nung tinulak. please advise. thanks!
May 22nd, 2003 11:03 AM #3
kung tinulak lang para itabi ok lang yan... wala pa namang harm na magagawa yan.. ang masama is to tow it with the driving wheels down (even if its in neutral)...
- 1
May 22nd, 2003 12:13 PM #5
kadyot? as in parang push starting the car?
meron sa manual nung accord namin.. parang you have to reach a certain rolling level or something... ewan.. nde ko pinapansin.. basta may jumper cable lang ako sa trunk.e hehe
- Jan 2003
- 611
May 22nd, 2003 02:05 PM #7
As the others mentioned, basta neutral OK lang itulak.
Namatayan din yung bro ko sa gitna ng Ayala Ave the other day. Buti lang at nakasunod ako at mabilis ko na-switch and batteries para i-start yung kotse or else mapapatow kami niyan.
It works best if you always keep jumper cables and a tow rope handy para mabilis ma mobilize yung car should the battery die down. Just make sure that you get a jumper cable with at least a 200amp rating. Based on experience, the 100amp ones cant carry enough juice to start another car.
Ba't masama i-tow on the driving wheels? It puts stress on the drivetrain axles and suspension... CMMIW.
May 22nd, 2003 02:40 PM #8Ba't masama i-tow on the driving wheels? It puts stress on the drivetrain axles and suspension
May 22nd, 2003 03:38 PM #9
you can tow a matic car.. as long as teh drive wheels are lifted from the ground... or better yet.. if you get car trouble.. and you called a towing service.. ask for a flatbed truck.
May 22nd, 2003 05:48 PM #10
Originally Posted by HBOY
dati un kinakatok un volvo 940SE namin.. de hila ng van... naka N.. pero ayus na now.. anu ba mga mangyayari?
Nope Prius had variable speed/inverter Acs since its 2nd generation(~2004)....
A/c
