Quote Originally Posted by nim ra View Post
Toyota corolla xl 93 big body
Ok ba AISIN clutch ???
May nkagamit n b LUK clutch for same ride ???
TIA
Aisin is the original equipment since the transaxle was manufactured by aisin Warner, a Toyota subsidiary.
Luk is a good direct replacement.
Regardless of what brand, it depends on how it is installed and how the flywheel and the pressure plate are prepared. Hands off the friction surfaces specially oily hands. Replace as a set, pressure plate, clutch release bearing, pilot bearing, clutch disc and as a might as well, the rear main engine oil seal.
