Results 11 to 20 of 79
Tsikot Member Rank 3
- Nov 2002
- 1,772
September 28th, 2005 11:05 AM #11btw a squeaking sound in the clutch pedal, plus, sometimes total loss of clutch pedal resistance (e.g. the clutch pedal drops to the floor, no resistance, and can't change gears anymore) what is this? happened to me 3 times now. Pretty annoying/unnerving. But the clutch pedal worked itself back up within a few minutes, and I went on with my driving..
Tsikot Member Rank 5
- Nov 2003
- 3,848
October 11th, 2005 11:33 PM #13if you can find uprated pressure plates and discs with material with a higher coefficient of friction better. pero depends on the car.
also prepare for stiffer pedal pressure because of the upgraded pressure plate.
Toyota is my choice
- Aug 2005
- 2,063
October 12th, 2005 06:26 PM #14in how many kilometers or years should we replace our clutch (manual) transmission.?
- Dec 2003
- 546
October 12th, 2005 06:30 PM #15depende
pag clutch driver ka baka wala pang isang taon pudpud na clutch mo.
OEM clutch are said to last 150,000km before being replaced. pag clutch driver ka, it could cut its life to 30,000km or even less
October 12th, 2005 10:31 PM #16
Originally Posted by finchy18
Just feel the clutch pedal when it starts to slip and lose power when you needed it most.
October 12th, 2005 10:45 PM #17
ako nasa 50K KM palang medyo ramdam na manipis kasi pinagpractisan yun car ng dalawang newbee dati hehe...
ang estimate sakin ng toyota syempre taga...15K for the whole assembly
Toyota is my choice
- Aug 2005
- 2,063
October 12th, 2005 11:53 PM #18Originally Posted by Ungas
sorry sir.. im just a newbie trying to ask around..
thanx sa mga reply..Last edited by finchy18; October 12th, 2005 at 11:55 PM.
October 13th, 2005 01:02 PM #20
Mine has more than 80K++ readings ... pero di pa napapalitan ng clutch .... or any parts sa clutch.
i'm a yokohaman. altii, innova, wigo. ordinary driving. no issues.
Finding the Best Tire for You
