MISFITS, this is exactly what im telling my mechanic. But, he said walang ganun atang problem. Ang ginawa kse namin, nag lagay nang repair kit for master and secondary then adjust ung push rod, eto ba ung sa cluth pedal?.
Then, after magawa test drive. After 1 day, sa traffic. Nde na sya nag shift, and the car has been idle for so long.
I had no choice but to turn off the engine and shift to 1st then start, hanggat makarating sa shop. Naka shift naman ako to 2nd gear, w/o turning of the engine buti malapit lang ung shop kung saan ako tumigil.
Kinabukasan ni check ulit nila, and can't find what is causing the prob, kse nung pag start nung umaga, nde na sya umulit ni test drive din biniyahe sa traffic, wala.
Hanggat, inudjust ulet nila ung clutch double check the master and secondary, ayun. ika 3rd day ko na ngayon. So far wala pang problem. hopefully.
