Results 1 to 6 of 6
December 28th, 2005 02:15 PM #1
sabi kasi ng mekaniko ko, replace na daw dahil tumatagas.. pumunta ako sa other mekaniko for 2nd opinion sabi nila hindi daw ok pa naman, ano ba dapat? should be or not to be? and what is the purpose of these clutch master assembly?
December 28th, 2005 02:29 PM #2
sir, ganito ang gawin mo. check mo kung moist na yung master assembly. pag oo, then replace mo yung cylinder. may nabibiling replacement kit yan. minsan kasi ok pa yung piston sa loob, yung rubber lang ang pinapalitan.
basta remember to bleed the clutch after replacing...
December 29th, 2005 09:10 AM #3
kung malalim na ang tama sa master cylinder lining dapat replace na yan. kasi sisira lang ng rubber (repairkit) which in the long run will cost you more.
December 29th, 2005 09:49 AM #4
oo nga mga sir, na-inquire ko na how much it will cost, medyo mahal nga! hehehe! mga sir, may mararamdaman ka ba sa clutch or gear (symtoms) if ever may problem na yun assembly?
December 29th, 2005 10:32 AM #5
madalas mahirap i shift, lusok ang clutch or need mo pang bombahin para pumasok ang gear. try mo muna mag replace ng repair kit tapos pag di tumagal at nasira ulit, malamang master na yan.
December 29th, 2005 12:51 PM #6
ay ganun ba sir? kaya pala, hirap mag shift. salamat mga sir, bukas pa replace ko na . also the other problem sa car ko. salamat ulit mga sir,. happy new year!
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
