Does anyone know if this can be repaired and where? Someone told me they can inject silicon, some shops are able to do it?
My Pajero Gen1 overheat bad trip. Brand new fan * El Dorado 8k!
Yup, you need to put in silicone oil for the fan clutch.Just ask DIY master afrasay. I think his cousin (the mechanic) can do it. Its fairly easy to do.
Goodluck.
buy ka ng silicone tube (2) kay hanson sa denso banawe. biyaking mo yun center ng fan, yun may fins. then empty the 2 tubes into it. P70 ea ata isang tube. i eventually replaced the center of the fan kasi may leak. P500 ang clutch (center) ng fan.
Ok! Subukan ko to. Di ba mahirap biyakin yung center Fan? Anyway subukan ko bukas....Tnx! Balitaan ko kayo
tignan mo muna kung may leak or kung kalog na, pag meron na buy ka na lang surplus na matino. kung babaklasin mo naman-ylabe na dyes lang ang katapat nyan
perennial problem din yan nung gen1 ko. ang ginawa ng mekaniko, ni-rivet yung fan para sabay na sa ikot ng makina.
kaya ayun, dina ko pwede mag waterfording.![]()
Dapat dun gamitan ng impact driver para siguradong hindi masisira yung grip nung turnilyo. Ginawa ko na yan sa fan ng L300 namin. Di ko lang matandaan kung ilang tube yung nilagay kong silicone oil.![]()
Bogart d ba baliktad yung ikot nung fan (papunta sa Radiator)...d be pag high speed (hi way drive) papasok yung hangin? D ba masama yon?Originally posted by bogart
Mismo. ;)[i]Originally posted by kupaloids [i] Dapat dun gamitan ng impact driver para siguradong hindi masisira yung grip nung turnilyo. http://www.rcrevolution.com/phpbb/im...ote_noidea.gif[/IMG] [/B]
dehins bro, pareho pa rin ikot nun, yun nga lang sabay palagi sa ikot ng engine yun, medyo(medyo lang) may dagdag load sa waterpump yun, gamit kasi nung clutch is to dampen stress sa waterpump and also a thermostatOriginally posted by frt
yup tama si rodcarolino. yung ikot ng fan is hindi papunta sa radiator, rather papunta sa makina.Originally posted by rodcarolino
ang sabi kasi nung magaling na mekaniko, walang dagdag load sa waterpump, kasi the engine itself is providing the power para umikot yung fan.
nawala lang yung freewheeling effect ng fan kapag high speed ka or low temp or kapag nadaan ka sa baha.
anyway, ibabalik ko din sa clutch type system yun sooner or later.
Napagawa ko na ....replacement fan 1.6k! labor 300....sira na yung fan d na ubra silicon....pinatangal ko na din thermostat sira na kasi....ayaw naman uminit ngayon he hehe...anyways tnx sa mga advise!
Nako bakit mo inalis thermostat? BAD iyan. Better get a new one ASAP.
Mas mainit pa sa ambient temp ang ideal operating ng makina. Saka tanghali lang mainit sa atin. We also drive in the mornings and at night. We also go to Baguio and Tagaytay.
Sama ng nangyari sa 4D56 namin dati nung inalis ang thermostat. Bagsak ang power saka laklak sa krudo after a while. Nung una lang maganda kasi walang overheat.
Kaya nung ayaw uminit ng makina nung LC II namin, naghanap kami ng thermostat. Napakahirap pala maghanap ng thermostat para sa 22R engine. Wala nang may alam sa Banawe kung ano ang 22R. hehehe.
Saan ba ang location ng Thermostat Valve ng L300(4D56)Originally Posted by OTEP
