Clutch fluid = Brake fluid
If you have extra brake fluid lying around, pwede na yun. Pa-check mo rin baka may leak, kaya mababa na sya. Pag sobrang baba, you won't be able to disengage the clutch, therefore, hindi ka makaka-kambyo.
The mechanic's probably not pulling your leg. Unless your clutch is not hydraulic. :D
