Page 23 of 37 FirstFirst ... 1319202122232425262733 ... LastLast
Results 221 to 230 of 370
    Nov 2007
    #221
    Mas recommended ba bro na pababa nalang tranny agad, overhaul/repair?
    Mukhang baba tranny na nga especially if always hindi na umaakyat ng 2nd gear. bago pala atf mo
    Jun 2005
    #222
    Sa mga nagpadialysis ng honda and used a cheap ATF then honda ATF ang final na ginamit, nagkaroon ba ng damage ang mga ATF nyo?
    Jun 2007
    #223
    Quote Originally Posted by sirkosero View Post
    Kalokohan lang Dialysis na yan. Napakadaming klaseng ATF. Hindi lahat ng ATF pwede. May multi vehicle ATF na di kasama Honda. Meron din pwede sa Honda ATF-Z1 pero di pwede sa ATF-DW1 katulad ng Spirax S5 ng Shell. Kelangan mong palitan ATF including yung nasa Torque Converter kung mali nailagay mo.
    Bilhan mo na ng ATF Cooler tapos bili ka rin ng Inline ATF Filter(1k) sa Honda. Directional yung flow filter. Di mo na kelangan pang mag change ng ATF. Filter na lang papalitan mo at add ng konting ATF.
    #224
    Imho as long as the ATF manufacturer is a trusted brand and it meets your ATF specs, you should be fine. Naka list naman sa bottle yung different specs na namimeet nya.
    #225
    Agree with this one. For sure the manufacturer will sue anyone who falsely claim to be a producer of any product that is approved by the manufacturer. There is a cost in applying for certification iirc. The producer would surely want that certification in their package to tell the world that they do pass certain criteria or standard.
    Mar 2005
    #226
    Quote Originally Posted by jmpet626 View Post
    Used Castrol Transmax Multivehicle for my 09 Santa Fe. According sa Manual 10.9 quarts pero 9 quarts lang nagamit ng fluid exchanger ng Exalta Banawe. Rated for Hyundai SP3 yung Transmax at mas mura kesa sa oem * 340 per liter.
    Attachment 21012
    Castrol Singapore - Castrol Transmax Multivehicle
    Attachment 21013Attachment 21013
    Nung dinrain yung ATF medyo kulay brown na siya. Di ko nga lang nakunan yung before.
    Due na ko for ATF replacement for my Santa Fe that requires SPIII . Naka 50,000kms of mostly heavy traffic driving na since last replacement ko ng ATF. Now wala na daw Transmax sa Ace Hardware.
    Anyone tried Mitasu Multi Vehicle ATF? 1710 pesos sa True Value. First time to see a Multi Vehicle ATF na pwede din sa CVT as per specs below.
    MITASU JAPAN MULTI VEHICLE ATF Synthetic Blended - synthetic, highly effective universal liquid for automatic transmissions, is suitable for the broad range of application. The innovation formula of this product guarantees smooth gear shifting in automatic transmissions of the car. High viscosity index provides effective greasing of details at the most high temperatures of service or low starting temperatures. Liquid for Automatic Transmissions of MITASU JAPAN MULTI VEHICLE ATF Synthetic Blended meets the requirements of the JASO 1A tests (Japanese Automotive Standards Organization) and HONDA.
    APPLICATION
    MITASU JAPAN MULTI VEHICLE ATF Synthetic Blended is widely used in cars of the Japanese and Korean producers. Possesses anti-vibration properties. Is suitable for some hydraulic transmissions, mechanisms with servoupravleniye and hydraulic to system. Is suitable for use in variators with engine displacement up to 2 l. also conforms to requirements of the LFW-1 test.
    THE ADMISSIONS / PRODUCTION TECHNOLOGY MEET THE REQUIREMENTS
    Completely is suitable for the following models of automatic transmissions and variators:
    • TOYOTA AFT TYPE T-IV, T-III, D-II, D-III
    • TOYOTA JWS 2312D, JWS 3309
    • TOYOTA #08886-81015, #08886-00405
    • NISSAN MATIC FLUID D, J, K
    • HONDA ULTRA ATF-1, ATF Z-1
    • MITSUBISHI DIA QUEEN ATF SP-II, SP-III
    • MITSUBISHI ATF-II, ATF J2, PSF3
    • SUZUKI AT Oil, Oil Special
    • SUZUKI S-CVT
    • SUZUKI ATF (5D06), (2384K)
    • SUZUKI ATF (3314), (3317)
    • SUBARU ATF, ATF-HP, i-CVT Fluid
    • SUBARU ECVT Fluid
    • MAZDA ATF D-II, M-V, F-1
    • ISUZU Besco ATF-II, III
    • HYUNDAY/KIA: Red-1, SP-II, SP-III
    • FORD M, MERCON
    • GM D-III
    • MERCEDES-BENZ 236.9
    • CHRYSLER ATF +3/+4
    • DAIHATSU Ammix ATF D-III Multi
    • HINO Blue Ribbon ATF
    Technical characteristics
    Technical quality Method Result
    Density at 15 °C ASTM D-4052 0.8478
    Temperature of flash, °C ASTM D-92 198
    Temperature of hardening, °C ASTM D-97 - 45
    Color Visual Red
    Viscosity index ASTM D-2270 181
    Kinematic viscosity at 40 °C (cSt) ASTM D-445 38.3
    Kinematic viscosity at 100 °C (cSt) ASTM D-445 7.41
    #227
    IMHO Mitasu is a reliable brand. I believe you can use that. Is that the 1ltr or the 1 gal. can?
    I looked for specs on suzuki scvt fluid. parang wala naman application, maybe its for early gen cvts...
    Jul 2016
    #229
    Good morning mga sir! I just have an inquiry regarding changing ATF. I want to completely change the fluid inside my tranny. I asked a mechanic ng friend ko and sabi niya na no need na daw for a dialysis. Ibaba lng daw oil pan at linisan then refill. Question is pag drop oil pan lang diba hindi natatangal lahat ng fluid lalo na yung nasa Torque Converter? And besides ang alam ko advisable lang eto for manual tranny which is drain and refill (correct me if I'm wrong). Previously manual car ko but now ng palit na ako ng automatic. Really confused. Ano ba mas maganda for a complete change in ATF. Worried na din kasi ako dahil parang may burnt smell na ung fluid the last time I checked. BTW, ride is Mitsu Lancer 98 GLXI AT with InvecsII/sports mode transmission. Really appreciate all feedback and comments. post lang mga sir. maraming salamat and more power sa forum na eto.
    Jan 2009
    #230
    Personally, I don't trust Mitasu. It's not even made in Japan (Russian-made). Then there's these text about it being "Manufactured by an ISO 9001:2008 certified company for Mitasu Oil....".
    Then there's also its claim that this same oil can be used in both traditional A/T and CVT... what a load of c!*p!
    It also uses the word "Suitable" when talking about compatibility with different transmissions. Anyway, before you pour that thing into "the most complex piece of machinery in your vehicle" (the A/T), watch the following video.
    Transmission Fluid Facts - YouTube
Changing ATF Fluid completely (DIALYSIS PROCESS)
