Results 181 to 190 of 370
- Oct 2014
- 341
November 17th, 2014 06:14 PM #181Ano po ba recommended na mileage to have the ATF replalced? Saka what kind of ATF kaya pwede ilagay for a Mazda 3 2006?
December 7th, 2014 09:03 PM #182
Mga ka tsikot kulang kulang ba 3K ang magagastos ko sa Sentra GS 1.6 ko kapag pinadialysis ko to?
Kasi parang nalulunod ung transmission kapag inaapakan ng todo tas may pumapadyak sa unang gear. Tas pag set from D to park or reverse may pumapadyak.
- Aug 2005
- 183
January 27th, 2015 03:25 PM #183Just got home from customer cradle for dialysis...have a fd civic...bought 10 liters of atf-dw from honda alabang...bigat sa bulsa nasa 6,400 tapos labor is 1k. During the process, nakita ko na almost black yung fluid na lumalabas sa tranny...sabi nung mechanic abot naman daw yung 10. Sa ibang cars daw inaabot ng 15 liters pag sobra itim. Whew, pag dating ng 10 liters luminis na din clear red...pansin yung difference...thanks junior of customer cradle...
- Nov 2006
- 11
February 20th, 2015 01:09 AM #184Had my at dialysis done today in EXALTA along nicanor roxas.
Labor 600
Atf top 1 dexron III..... 8 li consumed. ultrashop is cheapest at 180 per liter. Other shop 200.
February 25th, 2015 01:20 PM #185
Hi, just bought 2nd hand 2000 nissan exalta STA. casa maintained. never into AT, pero since magprapractice wife ko how to drive kaya napilitan. ugali ko kasi pag nabili ng 2nd hand, tune up agad so.. Last week, replaced engine oil(Castrol MAGNATEC 10W-40), vc gasket(Japan replacement), oil seal(distributor), spark plug(NGK), oil filter(VIC), air filter(replacement), fuel filter(VIC) and ATF(MAG1 - Dexron III)... Since new sa akin ang AT, read this forum and dami ko di alam.
What was done when I change my ATF from my mekaniko.
1. drain the ATF(around 4.5 liters of ATF, sinukat namin while draining the ATF) color is light brown and I haven't smell(no idea since new ako in terms of AT) kung amoy sunog or oil
2. remove oil pan(may moisture na and need na lagyan ng gasket maker(gray)
3. remove filter/screen(salaan ng dumi)
4. nilinis ung oil pan(may residue), magnet(may residue), and filter
5. Balik lahat ng parts and refill MAG1 Dexron III 4.5liters.
6. We start the car(on idle), so far ok andar.
7. we shifted the AT from P down to 1(ok rin naman) and naka apak lang ako sa brake kasi check ng mekaniko ko kung may kaibang tunog sa tranny pero wala narinig ung mekaniko ko.
8. then tested on the road and I feel medyo mas gumaan ung takbo as well as sa shifting.
Question:
1. Yung procedure ba ginawa namin is talaga bang na drain ung ATF? I know di naman talaga ma drain lahat, sa tingin nyo mga ilang percent ung na drain?
2. Do I need pa ba pa dialysis?
3. tama ba yung ATF na isinalang ko?
TIA - Joms
February 25th, 2015 08:57 PM #186
1. Ok naman procedure pero sana pinaadar mo kahit 10 sec lang after ma-drain, may naiwan pa kc sa torque converter mga 30% yun. After 1,000kms palit ka na lang ulit using simple drain and refill.
2. No need na kasi nagawa mo na baba pan at linis filter.
3. See your owners manual or ask nissan casa if tama dexron III but afaik tama lang dex3 sa car mo. But be sure. Mahal rebuild tranny e.Fasten your seatbelt! Or else... Driven To Thrill!
- Sep 2014
- 2
March 13th, 2015 12:53 PM #188
Thank you sir Ry_Tower. Wala po ako owners manual for my nissan, try ko nalang ask sa casa kung ano specs for AT.
- Jul 2014
- 162
March 13th, 2015 04:08 PM #190
mga sir for first time mag palit ng ATF fluid (40k km)
is it advisable na po ba mag dialysis? o pede pa yun patulo system muna?
yun sa fortuner kasi namin nuon dialysis na ginawa namin kasi lumagpas na sya eh nasa 50k+ na
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
