Sir yung transtech ATF dialysis sa Servitek Dasma yun along Aguinaldo highway. yung malapit opposite Hyundai Dasmarinas. Yung Sta.Fe ng nanay ko used a total of 12 liters ATF flushing at refill na po yun.I forgot how much yung damage sa wallet. Ok naman results.
sa mga nagaalanagan regarding the ATF Fluid.
1. i suggest you go to CASA, then check the label of the ATF Fluid may mga nakalagay na grade duon like DEXRON, CAT and etc.
2. go to the suking gasolinahan, have the same exact rating as the CASA is selling.
i tried this transtech machine at Autotechnica at the fort when i bought my civic last 2006. initially they require me 20 liters of ATF since madumi na talga ATF ko and they are charging 1k for the process.
i was able to ask the repercussion so ginawa ko ung ginawa ko sa taas - imagine sa casa if i recall it correctly 500 petot per liter ng ATF multiplied by 20 so that is 10k agad. eh nagcanvass ako sa petron ung ATF nila ang pinakacompatible sa ATF ng 96 civic that time at 150 petot per liter so ang nagastos ko alng is 4000 petot kasama na transtech.
by the way, sumobra pala ATF ko and they used only around 15 liters kaya may pang flush and drain pa ako.
but now sliding na AT ng civic ko may time na pagmalamig makina ayaw umatras or magsegunda.
Our Terrano's A/T doesn't respond immediately when putting it on D, kelangan mga 30secs muna, so ginagawa ko sa umaga is ilagay muna sa 2 then lipat sa D. Will dialysis cure it? Saka pag dialysis ba binubuksan din nila ang oil pan and clean it, magnet(s), and strainer? Lastly, any shop doing it on Evangelista?
* Shibby: hindi naman Sir. talagang due for palit ng tranny oil lang sya. actually na-salaes talk ako kya napa ATF dialysis pa hehe.
Sir babkalakal,
Yun Goodyear Servitek po ba to? How much po yun labor cost for a Santa Fe ? Hehehe same po kasi ng ride ko e so swak yun post nyo . I'll be bringing my own ATF na Lang.bale 12 liters pala kailangan? Hmmmm makapg ipon na pala.
Gaano katagal ginawa?mabuti me ATF dialysis machine na dito sa Dasma
Napadaan ako ng Evangelista kanina, sa may Baņados (Estrella cor. Evangelista), ask ako kung magkano A/T dialysis, sabi 2.5k, tanong ko kung kasama na ATF, sabi hindi pa?!? Dunno kung mechanic nga yung napagtanungan ko dun pero nakauniform naman, sabi ko sige na lang![]()
Finally having it done at Exalta, 600 petots charge nila, then I bought my own ATF 15 liters, total damage Php3600. So far smooth shifting na
[ame=http://www.youtube.com/watch?v=hETgE-S1Eu4]MotorVac Trans Tech System Instruction Video - YouTube[/ame]
additional info lang po
Naka-schedule bukas umaga sa Banawe for tranny dialysis ang 1996 Corolla Gli ko, sabi ng technician, needs 6 liters - low grade ATF for flushing of old ATF, pang-mumog ng tranny, after certain period of time, depende daw sa fluid pressure ng tranny, ibubuhos naman ang 7 - 8 liters of Dextron lll grade ATF for final lubricant, iyon na daw yun! Around one hour ang process.
Ano kaya ang lowest priced ATF na pwede gamitin, for flushing lang naman yun. I intend to use, Mobil or Whiz ATF sa final exchange, okey na kaya? Noon nagpalit ng ATF strainer/filter, Whiz ang ginamit, around four liters yata nagamit.
Buti na lang, hindi ako natuloy kanina sa Banawe, read some more tips sa BITOG, regarding ATF change. Found out, pwede pala drain and refill lang, kaya ko na DIY yun. Bought 4 liters - Whiz Dexron lll grade ATF, same sa refill noon ibaba oil pan and changed strainer, almost 8 mos na yata. Naisip ko nga din, dapat same ang brand ng ATF na gagamitin, baka nga magkaroon ng reactions pag iba-iba. Thanks, beni23!
Ayos kung ganun.
I just changed my ATF fluid in Fronte Banawe. 8:30AM pa lang andun na ko, madame pala tao dun pag weekend so dapat agahan talaga, 9 AM pala bukas nila. Pero bago pa ko pumunta dun bumili na ko ng ATF fluid Mercon V sa Mazford muna. Pag dating sa Fronte derecho agad sa cashier at sabihin nyo lang pa dialysis ng ATF at meron ka dala sariling fluid. Ok naman ang gawa nila sakto 1hr lang ang process. Yung mga mekaniko nila medyo makulit nga lang, aalukin ka talaga ng mga products nila like pang flushing muna, pang linis ng ATF filter. Wag nyo lang pansinin basta kamo dialysis lang ang babayaran nyo![]()
Just did second D&F of my car's ATF after almost 3k kms, drained almost 3.5 liters with dark red color but seen no contaminants or debris, not like the first time when dropped pan and replace strainer/filter, almost 4 liters was drained with very dark color and has what looks like dissolved dust. Will drive to Nueva Ecija this coming weekend, that's more than 350km trip via NLEX, SCTEX to Tarlac-Sta Rosa hiway, planning to drive at an average of 100kph at the expressway to release whatever stubborn debris there maybe, will do the third D&F when I come back. BTW, I use Whiz Dexron lll ATF, Product of USA, used seven liters,so far, will buy addl 4 liters for the third, I hope, it's the final D&F.
My car is ford escape around 3 1/2 years old. Bumili ako ng 8 liters of ATF Mercon-V sabi ng mekaniko sa Fronte kukulangin daw yun. Pero during the dialysis, nakita nila na hinde naman ganun ka itim ang old ATF ko so after a few flushes, same color na yung indicator sa machine at my new ATF. Maganda yung machine nila kase may indicator yun kung malinis or madumi. Php 700 po ang labor sa dialysis.
