Results 31 to 40 of 370
- Jul 2008
- 479
August 28th, 2012 11:24 AM #31planning on having this on my vehicles pero after reading this article: http://www.ricksfreeautorepairadvice...-the-right-way
will just do the CASA way of draining and changing the ATF every 40t KMS. Siguro this dialysis process is good for high-mileage-not too-often changed ATF vehicles.
September 1st, 2012 06:03 PM #32
basta alaga sa ATF change, the AT transmission will last with the car,, pag bagong atf change tapos everything is fine with the electronics tapos matagal bago umalis from N/P?R to D, baka mga solenoid or worse valve body sa internals ng AT transmission..
kase the valve body and solenoids pumps and controls the flow of ATF fluid to generate the required torque slip...
September 1st, 2012 06:18 PM #33
^ How many kilometers/mos. ka bago magpapalit ng ATF sir miko? And what do you use/recommend?
- May 2012
- 186
September 1st, 2012 06:39 PM #34Ako basta every jan or every year regardless kung gaano kalayo tinakbo pinapalitan ko atf unless siguro di mo talaga ginagamit he he. Never had any problem with my 9 year old car. Kung dialysis siguro ang gagawin ko nalang eh once a month nalang ako magpapalit sa dami ng atf na gagamitin never used any oil but ung sa casa
September 1st, 2012 09:33 PM #35
kung hindi abused or hindi ginagamit sa load towing ang vehicle, safe ang 40,000kms 50,000kms interval...
if hinaharurot o meh heavy load and towing sa vehicle, safe ang 20,000kms to 30,000kms interval...
that is for mineral type nang ATF fluids...
for synthetic ATF fluids which is mas mahal around 800/liter(royal purple and mobil syn atf)
an interval of 80,000kms is recommended... kahit heavy towing and driving pa...
right now gamit ko synthetic type, peace of mind and confidence, ahahaha...
September 2nd, 2012 10:15 AM #36
Mga sirs, paano pag normal na change ng atf fluid lang, ilang liters kaya ang city 06? Tia!
September 2nd, 2012 12:15 PM #37
im sure sir nasa manual po sir yung amount nang ATF po sa honda city 06, if wala sa inyo manual you can ask the casa, they know it for sure...
the earlier you change the ATF before its recommended life much better,, heat is the primary enemy nang atf fluids...
that's why synthetic ATF last for a minimum of 80,000kms.
as the vehicle is driven, the atf fluid gradually changes its color due to oxidation, sa una hindi mo makita na madumi na kase usually pag tinignan mo mapula pa (naked eye) , pero pag naka kuha ka nang around 1 liter at nilagay mo sa transparent na bote, makikita mo nadark na siya.. hindi na red, parang nearing brownish color na...
if the atf fluids gets to the point of becoming brown-dark brown,,the transmission is in serious risk of getting damaged, dahil hindi na correct yung atf properties plus the wear will increase drastically causing problems on the valve bodies and solenoids inside the tranny...
BANNED BANNED BANNED
- Aug 2012
- 113
December 7th, 2012 11:34 PM #38Kung sa years, paano ang sukatan kung kelan mag change atf? Kasi aabutin ng 6 years bago ako maka 40,000 kms.
Ang honda vehicles pwede ba gumamit ng non-honda brand atf?
December 7th, 2012 11:52 PM #39
may dipstick para sa ATF. pwede tignan ung color appearance, level (if hot or cold) and ung smell ng fluid.
- Aug 2009
- 420
January 5th, 2013 10:27 PM #40
