Results 1 to 5 of 5
    Jan 2011
    sirs, just wondering over the DIY ATF change oil i did on my xwind xuv '05 yesterday. what i did was to drain the ATF from its oil pan and only 2 liters was drained. is this normal? with a big tranny such as xuv? what i did was to replace the same amount thru the dipstick tube. however, bumagal ngayon ang sasakyan. any ideas kung anong dapat kung gawin dito? where can i find the ATF filter? is it beneath the oil pan?
    Nov 2014
    guys, any idea if the crosswind AT has a filter inside?
    Jul 2014
    Meron filter
    Jul 2014
    Sir okay ba ang level ng atf?
    Dec 2009
    Quote Originally Posted by shelu View Post
    when you said na you drained the ATF, did you mean by;
    1. draining through a drain plug?
    2. draining by removing the whole oil pan which exposes the atf filter?
change atf oil in xwind xuv
