Results 1 to 8 of 8
    Apr 2008
    Hello po,
    Merun pong tog sound when i release the clutch on 1st 2nd or even 3rd gear parang tunog jack rabbit. Na test ko rin po from full stop and 1st gear ko din dahan dahan release ng clutch (walang gas na apak) before ma full release ko yun clutch merun din "tog" na sound. Anyone encounter same issue? Any idea anu po yun sira?
    MAraming salamat po.
    normally pag ganyan, either release bearing or pressure plate. maybe both.
    anong oto at when napalitan ng clutch?
    Apr 2008
    sir kia picanto po 2008 model. never pa napalitan clutch.
    ahh clutch na nga iyan, walang duda.
    wag mo na pagalin baka madale pati gearbox mo.
    after clutch replacement, palit gear oil ka na din, Sir
    i agree that it has to be the clutch.... na experience ko na din yan eh.
    Oct 2009
    minsan engine support din..
    malakas ba ung tog sound
    Apr 2008
    medyo sir may kalakasan tunog.
    Apr 2008
    False alarm! ngpalit ako front shock without replacing shock mount dito ko napansin malakas yun tunog. sinabi sa akin ng mechanic na palitan din daw yun mounting. once nakahanap at nakabili ako pinakabit ko mounting nawala yun tunog. pinadouble check ko sa mechanic wala naman daw prob yun clutch ko.
"tog sound" when releasing clutch
