Results 1 to 10 of 14
- 6
November 6th, 2008 08:12 AM #1Help mga gurus! I bought a second hand Nissan X-trail 250x and I noticed that when I accelerate, the body of my car shakes. I already changed all the 4 tires and rims, have it balanced and aligned but I still experience the same problem. I also have it repaired in casa and they noticed that the cross membrane was already repaired, it has a welding spot on the connecting side and the connecting rod, ball joint was all busted because of the miss aligned cross membrane. So their recommendation is to change the cross membrane, ball joints, connecting rods, have it camber and align again. But after all these changes and repairs, the problem is still there and now their diagnosis is to check and change the torque converter or axle assembly. I already spent a huge amount of money to fix this problem and I don't want to let go another huge amount of money without knowing the right fix for my car problem. So really need your expertise and opinion on my problem, please help
- Nov 2008
- 2
November 6th, 2008 08:23 AM #2The mere fact that your car shakes only when you accelerate is a symptom that a physical chassis imbalance exists in your car due to increased torque. Please have your car underchassis diagnosed inclusive of ALL rubber mounts and flywheel vibration isolator.(This is a rubber coupling which links your flywheel to the flywheel hub). Also test bench test your torque converter.
November 6th, 2008 08:48 AM #3
sir na major accident po ba yan? sir miss align crossmember po.. wheel setback yan.. i mean yung wheelbase nya iba ang sukat well pag ganyan dapat mahina na yung returnability ng steering wheel nyo po.. nakakaranas po kyo ng ganun?
THE AUTO SPECIALIST
- Mar 2006
- 607
November 6th, 2008 08:51 AM #4You may consider visiting some experts when it comes to this like
tranny shops
underchassis specialists
or the guys who are good at drivability problems
you can get some accurate answers from them instantly
- Nov 2006
- 299
November 6th, 2008 02:05 PM #5when does it happen,slow or high speed? what speed did the vibration start?does it also happen in park while engine running?did the vehicle involve in colission?help me answer this question and i will help find the cause of this problem.
- 6
November 6th, 2008 05:33 PM #6thanks for all the inputs. anyway to answer some of your questions, the vibration happens everytime I accelerates, minsan kahit 30 KPH palang nag start na syang mag vibrate, especially when you press the gas pedal hard, pero pag free wheel na ako even mabilis na yung takbo nawawala yung vibration. Yung returnability ng steering wheel nya medyo mabagal when I turn left and medyo kapos yung left turn nya compare sa right, sabi sa akin noong last mechanic na nag check hinabol daw kasi yung straight steering wheel ko versus the wheel alignment. I think major accident talaga yung nagyari sa car na ito. Sir Bambino, please refer naman some names of shop that you mentioned and Sir Du1em, pano ba yung bench test sa torque converter and what shop you recommend that offers underchasis diagnosis?
November 6th, 2008 05:47 PM #7
Ok pa ba engine supports mo?
- 6
November 6th, 2008 06:01 PM #8nabanggit din ng mechanic yung engine support, pero sabi nya hindi daw yung ang major problem kasi hindi daw dapat grabe yung vibration nya kung engine support lang, kasi hindi pa naman daw ganon ka busted yung engine support ng car.
November 6th, 2008 06:24 PM #9
engine support and transmision support try mo din contact yung dating may ari ng x trail
- 6
November 6th, 2008 06:34 PM #10pinagtataguan na ako noong dating may-ari, last time na nakausap ko sya dine-deny nya yung sira ng car, mali ko lang hindi ko sya na test drive sa highway, twice ko sya na drive bago ko bilin pero sa loob lang subdivision nila kaya hindi ko masyadong mapuna yung vibration.
Planning to buy a second car. Help me choose. Honda accord has 71k mileage for ₱465,000 Nissan...
honda accord 2014 2.4L vs nissan altima 2015
