Results 11 to 16 of 16
April 11th, 2006 09:42 AM #13
ayus a...never thought of that...oo nga naman...kesa naman you'll get stuck when putting your shift stick on first gear. asteg...
- Jun 2005
- 325
April 11th, 2006 09:45 AM #14that happened to me a long, long time ago when i still had my '93 corolla xe - clutch master and slave yung problem. pagpasok sa first gear, di na matanggal sa first at di maibalik sa neutral.
April 11th, 2006 10:20 AM #15
hmmm... the "wheeeng" sound is kinda worrying, my friend-mechanic is overhauling a tranny right now which has a similar symptom (wheeeng sound).
I hope in your case it's not that bad. Start with the cheapest solution muna, clutch bleed and replace your transmission oil, if the problem persist, time to have your clutch components checked, baka worn out na.
if after having the clutch components replaced and the problem is still there, then that could be a transmission problem na.
HTH
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 11th, 2006 10:55 PM #16the main reason the overhaul a manual tranny is when the synchros or gears go. this could be another reason that the gear is stuck pero in this case i highly doubt it.
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
