Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    whay kind of car? column or floor shift?
    temporary solution is to start from 2nd.
    Jun 2005
    that happened to me a long, long time ago when i still had my '93 corolla xe - clutch master and slave yung problem. pagpasok sa first gear, di na matanggal sa first at di maibalik sa neutral.
    Oct 2005
    ayus a...never thought of that...oo nga naman...kesa naman you'll get stuck when putting your shift stick on first gear. asteg...
    hmmm... the "wheeeng" sound is kinda worrying, my friend-mechanic is overhauling a tranny right now which has a similar symptom (wheeeng sound).
    I hope in your case it's not that bad. Start with the cheapest solution muna, clutch bleed and replace your transmission oil, if the problem persist, time to have your clutch components checked, baka worn out na.
    if after having the clutch components replaced and the problem is still there, then that could be a transmission problem na.
    HTH
    Nov 2003
    the main reason the overhaul a manual tranny is when the synchros or gears go. this could be another reason that the gear is stuck pero in this case i highly doubt it.
ayaw magshift from 1st gear...
