Results 1 to 8 of 8
    Feb 2007
    if your tranny is:
    having a strong jerk from first to second gear
    and
    pag nasa "D" then naka-tapak sa brake pero may strong noise
    na parang gusto ng tumakbo (mas malakas sa noise and jerk ng naka-brake while nasa "R")
    mga sign ba ng sirang transmission yan? or worn out?
    if yes, pano gagawen? pano aayusin?
    or hindi kaya sa differential? what do you think?
    thanks a lot...
    Feb 2007
    sorry... pahabol:
    eto ung arrangement ng gears ko:
    P-R-N-D4-D3-2-1
    ano ba dapat lagi kong gamit? D4 or D3?
    para san ung 2 and 1?
    ano pipiliin ko pag downhill?
    e pag uphill?
    thanks..
    bump for a cause..
    May 2004
    Quote Originally Posted by coca-cola View Post
    sorry... pahabol:
    P-R-N-D4-D3-2-1
    e pag uphill?
    thanks..
    bump for a cause..
    Dapat naka D4 lagi (Drive-4spd.), kung may overdrive button ka dapat naka-on lagi (it is like the 5th gear) para mas matipid sa gas at mababa ang RPM, on full stops I tend to shift to N (neutral) to save a bit of petrol. Pag -uphill ok na yang D4, pag nahirapan I shift down to 2, pag-downhill naman D4 din then I shift down to 2 to engine brake for slowing down before I apply the brakes.
    May 2004
    if your tranny is:
    and
    thanks a lot...
    Pa-check mo na lang sa reputable transmission shop baka kailangan ng i-overhaul or baka service lang naman. Usually pag mataas na ang mileage ay kailangan na ding i-overhaul ang tranny for best performance.
    May 2004
    I noticed your location, tiga Las Pinas ka pala, sa Moonwalk ako lumaki since '72, recommend ko dalhin mo sa Prens Marketing (Auto-Supply bago mag Ayala Alabang along Alabang-Zapote Rd.), honest sila at magaling, hanapin mo si Manny, he used to service my '80 Toyota Liftback and my 1st car an '82 Ford Laser
    Good Luck and enjoy your ride!
    Apr 2006
    if your tranny is:
    and
    thanks a lot...
    Simpleng check muna. Check mo muna engine mount and transmission support baka worn out na. Check also transmission fluid kung kailangan na ba palitan o wala lang sa level.
    Sep 2004
    try also checking your transmission fluid. it may be low, usually, automatic transmission doesnt need overhaul unless it was abused or lack maintenance
    Nov 2003
    yup, try to fix it in the cheapest way possible muna before jumping to the expensive conclusions.
Automatic Transmission (strong jerk)
