Results 21 to 40 of 41
    Feb 2017
    #21
    Quote Originally Posted by shift _king View Post
    To my fellow tsikoteers,
    We rebuild and repair automatic transmissions, located in imus cavite. Any transmission inquiries are welcome. Post nyo lang dito. Basta abot ng kaalaman natin, sasagutin ko ^_^. Also comments and additional information is most welcome... para makatulong.
    Hi,
    Ano contact number nyo po. May transmission issue po sa Fiesta 1.6 S 2011. Reverse problem po. I need help
    May shop po ba kayo? I'm from Imus, Cavite po. Thanks
    Pirate man
    Mar 2017
    #22
    Sir naka bili ako nissan Micra 2000 1.0 16v automatic nag jejerk pag nag papalit ng gear. Sabi ng mekaniko transmission na daw sabi 2nd opinion ko sabi engine mount. Kung possible transmission sya Sir meron ba tyo pyesa nun dito?
    We rebuild and repair automatic transmissions, located in imus cavite. Any transmission inquiries are welcome. Post nyo lang dito. Basta abot ng kaalaman natin, sasagutin ko ^_^. Also comments and additional information is most welcome... para makatulong.[/QUOTE]
    Oct 2015
    #23
    Mga sir pa update naman po ng List ng may mga trusted mechanics.
    Need ko po kasi magpalit ng transmission as per advise by Honda Dasma Casa.
    idsi City 08 po sakin.
    Apr 2006
    #24
    I have a 1998 corolla lovelife m/t that I want to convert into a/t. Advisable po ba ito.Mga magkano kaya estimated cost nito,parts and labor? Advisable ba ito o medyo complicated? Salamat in advance.
    May 2018
    #25
    Boss, magkano kya mggastos kpg ngpakbit ng oil seal sa transmission ksma labor po?
    Jul 2018
    #26
    Hi po. I know this thread was very old already but im hoping u cud still response.
    my car honda city E 2013
    i am not sure it the problem is my transmission but when i start accelerating my car, bago kumagat ng 3rd gear may tumutunog. pero kung mabilis na takbo nawawala na xa. ask ko sana kung anu prob? is it the transmission?
    Quote Originally Posted by ramil_ortizo View Post
    when was the last transmission oil changed?
    Jul 2018
    #28
    Hi po. Inquire po sana ako kc sa honda city E 2013 ko. when naka full stop ako then upon putting gas for acceleration pansin ko between 2nd to 3rd gear may tumutunog bago pumasok. ang tunog niya po ay parang palyadong transmission sa manual madalas ko napapansin. anu po ang sira? btw, san po banda shop nyo sa imus?
    Jul 2018
    #29
    my last ATF change nung 50k odo niya. ngaun 60k pa lang naman.
    maintenance intervals depend on time and distance. In the Philippines and malaysia we follow time because we have more traffic.
    as per Hondas recommendation for cvt fluid ..
    40000km or 24mo whichever comes first.
    Most filipinos have transmission issues because they do the interval they think is right.
    Jul 2018
    #31
    Actually i brought my car at shell service center in cavite when i my car reached 40,000 odo but the chief mechanic told me that I should reach to 50k for the change ATF. anyway, what would be the possible problem in the transmission in my car's case? i think the problem is not yet fatal but i need to bring it to an expert before it get worse.
    i no longer visit honda here in dasma because of the negative experience before with my brakes.
    thanks
    24mo is from Honda.. if you dont see how important that is then good luck with the repair
    Jul 2018
    #33
    thanks
    Jul 2018
    #34
    thanks
    Jul 2018
    #35
    thanks
    #36
    Curious question, why are you and your mechanic saying it is ATF?
    Isn't the Honda City since 2006 a CVT? Thereby requiring Honda CVTF replacement.
    And like StockEngine has said, it is your car. If you don't want to have it checked by Honda, just be prepared with your checkbook to pay for possible repairs the more you prolong and delay Honda servicing the vehicle.
    If Honda Dasma is not a place you are comfortable with, better look for another Honda Service Center then.
    My two cents.
    Jul 2018
    #37
    Quote Originally Posted by 17Sphynx17 View Post
    My two cents.
    No. Honda 2013 is ATF. I then already brought my car again to Honda Dasma and they told me na palakasin muna ang tunog at ibalik sa kanila para madali na ma trace.
    May 2019
    #38
    San po exact address nyo sa Imus at contact number?
    Narcing
    May 2019
    #39
    Quote Originally Posted by Narcing19 View Post
    Narcing
    Nahahaluan kasi yong automatic transmission apparently ng tubig. Nagpadialysis na rin po ako last April this year pero lumalabas na naman yong Check Transmission message at parang kulay gatas na naman yong ATF. Need na po ba pa-overhaul yong transmission? Ang unit ko po ay Isuzu Crosswind XTO 2001 model? Would appreciate any help.
    Jan 2008
    #40
    Since nahaluan ng tubig.. need nyan ng flushing or worst is overhaul. Have your radiator checked.. malamang dun galing yung tubig na humahalo sa transmission
Automatic Transmission Specialist in  Imus Cavite
