Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
    Apr 2016
    #21
    Quote Originally Posted by sirkosero View Post
    Mura lang naman ang T-IV sa toyota casa 1200 per gallon.
    Just recently i replace the ATF every oil change. Mura lang kasi talaga.
    Sir, are you using the old school 'drop pan' method or using a 'dialysis' type machine? which is better ba mga gurus?
    Jun 2005
    #22
    Mas maganda raw dialysis.
    For me, i just use drain and fill.
    Last march i changed ATF almost every week. Heheh.
    Nov 2007
    #23
    Sa Casa yan sir ATF change mo ? Or sa labas ? San po ba maganda mag pa ATF change baka may suggestions kayo mga boss salamat po
    #24
    bakit daw mas maganda ang dialysis method?
    Jun 2005
    #25
    Sabi ng iba para daw maflush ng maigi laman ng torque converter para lahat ng fluid fresh unlike drain and fill na may naiiwan sa sump at torque converter....
    Jun 2005
    #26
    Quote Originally Posted by kenzie View Post
    Its a straight forward job. Any half decent mechanic or siraniko can do it.
    I did mine DIY style in about 20 minutes
    #27
    I think kailangan padin ng "drop pan". Usually ang atf filter is located inside the pan or integrated sa pan mismo. So once in a while you have to replace the ATF filter/strainer too.
    Oct 2015
    #28
    mga sir how about po sa DCT?
    ang unit ko po ay Hyundai Accent CRDi Hatchback
    bale 50,000kms na po saken at ang napalitan ko pa lang ay gear oil last 35,000 kms pms ko.
    ang alam ko dry type ang DCT at di na kailangan ng transmission oil?
    so far ok pa rin naman ang takbo, may jerking akong nararamdaman kapag binigla ko apak sa gas pedal pero kung gradual ok at swabe naman.
    sa trafik or stop light laging lipat ako Neutral
    Jul 2017
    #29
    Quote Originally Posted by kircchoffs View Post
    Unussual ata yan. Have it chek
    Oct 2015
    #30
    Quote Originally Posted by wilsonprostaff View Post
    nailabas ko na po kasi sa casa sir di ko lang alam kung saang auto service shops na sanay sa DCT.
    according naman sa ibang naka DCT normal lang daw kapag binigla ang apak sa gas pedal.
    kung normal na apak ok naman
Automatic Transmission - How Many KMS Before Overhaul?
