Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    i am not sure kung tama yung pinaglagyan ko ng post ko. MODS, pasensya na po. anyway, my dilemma is i always tend to forget to release the hand break pag papaandarin ko na ung car. ang nangyayari nakakarating na ko sa kanto namin bago ko marealize na nakaengage pa yung handbreak. critical po ba yun? mga 2-3 times ng nangyari yun. do i have to have it checked or kahit hindi na? natatakot kasi ako na masira ung brakes or something. i am a newbie and it's my first car.
    Sep 2005
    matic ba yan?
    If it is just a short distance, then it should not be a problem. But if it is quite a distance then there's a danger that your engine will knock....
    So, you'd better be aware of disengaging the handbrake before you roll.....
    7202:bruce_lee:
    Maybe the red warning light in your dashboard should be enough to remind you that your handbrake is still engaged?
    on my manual car, hinde talaga aandar if engage ang handbrake ko, while on my matic car meron warning sound..
    Sep 2005
    sa akin pag naka hand brake.. aandar sya.. pero mabagal..
    I mean aandar siya but ma obvious mo naman na parang pigil yun takbo..
    Sep 2005
    nangyari na din sa akin yan once.. excited kasi.. at bagong labas yung sasakyan sa CASA.. tapos nag pa gas ako.. tapos pag alis sa gas station.. di ko na release handbrake.. siguro mga 2 kms na natakbo ko nung nakita ko.. kaya pala ang bagal nang takbo.
    happens to me a couple of times din but meron kasing alarm sound eh kaya nalaman ko hehehe
    Sep 2005
    Happend to me also, but just for a few feet. Malalaman mo naman sa takbo ng sasakyan.
  11. #11
    [SIZE=4]Maybe the red warning light in your dashboard should be enough to remind you that your handbrake is still engaged? [/SIZE]
    ulitin natin to.......
    hello, mararamdaman mo naman naglalabor ang makina!
    Nov 2006
    [SIZE=3]Maybe the red warning light in your dashboard should be enough to remind you that your handbrake is still engaged?[/SIZE]
    Quote Originally Posted by alwayz_yummy View Post
    Baka naman hindi nya masyadong mapansin yung indicator sa dashboard so I would sugest for you to put up a sign in front of you with BRIGHT LED lights everytime your handbrake is engaged.
    [SIZE=3]!!! YOUR HANDBRAKE is ENGAGED !!![/SIZE]
    [SIZE=3][/SIZE]
    Seriously, maybe you could do a chant for the sequence of items that you need to operate, something like steps or procedure.
    it comes with practice ... older drivers don't even think about it, their driving habits are so routine, their hand automatically goes to the handbrake soon after shifting to a gear
    you will learn that too
    Dec 2007
    Ramdam naman na pigil ang takbo ng sasakyan kung naka-engage ang handbrake, e. I hope you "get the feel" of your car sooner than later, para maiwasan ang damage sa car mo.
    A friend of mine drove our car for 6 kms at 40-50 kph. Pagdating sa destination, umusok lahat ng gulong (brake pads) at amoy burnt rubber.
    Hindi daw siya gumagamit ng handbrake sa sasakyan nila, puro kambyo lang daw ang gamit nilang pang-"anchor" ng sasakyan.
    And to think na mas maaga pa siyang natutong magmaneho kesa sa akin. Di pala naturuan nang maayos. Doktor pa naman ang tatay niya.
    thanks po sa lahat ng mga sumagot.
    Sep 2005
    Baka naman sa pag-park mo lang ginagamit yung hand brake? You should use it more often, like in traffic jams, at stop lights, on inclines, etc.
    Practice lang naman yan. You'll get the hang of it eventually.
    Personally, I'd rather be an idiot who moves his car with the hand brake still on ... rather than a bigger idiot who leaves his car with the hand brake off.
    nangyari na din sa car ko when i let my gf drive going home. palibhasa bago lang natuto mag drive, naka engage ang handbrake hanggang umabot kami sa bahay. di ko rin napansin ang dashboard kasi abala ako sa pa guide sa kanya baka mabangga kami.. ayun ang init ng lugnuts nung hawakan ko. parang plantsa..
    masasanay ka rin dyan. madali namang haplusin ang handbreak lever every time aandar ka na tulad ng pag haplos mo sa manibela. gawin mo nang habit yun. sa epekto, una mas matagal ka makakarating sa pupuntahan mo, mauuna maubos ang break pad / shoe mo sa likod ng mas maaga at sigurado lalakas sa konsumo.
    Sep 2008
    this happened to me when i was still new to driving nung college sa B12 ko.
    what i did to relieve me of the bad habit is use...
    ... yellow POST-ITs! hehehe...
    i place it on the hazard button area para lagi kong nahahagip ng tingin...
    ayun, after a month or so, habit ko na laging hawak ung handbrake when nakastop... release when ready to drive ulet...
    This thread reminds mo of my mistakes when i was still a newbie at driving.
    I was told to put the gear in first gear or reverse after engaging the handbrake when parking my car. Lalo na daw kapag incline yung parking space. Ang problema ko naman palagi kong nakakalimutan ilagay sa neutral yung gear. Pag start ko alog yung kotse. As in madalas nangyari ito. At one point naputol cable ng handbrake.
    Well now I have the habit of pressing the clutch pedal fully before starting the car kahit nailagay ko na sa neutral.
always forgetting to release handbreak
