Page 1 of 10 12345 ... LastLast
Results 1 to 20 of 370
    Apr 2010
    sirs may alam kayo nagpapalit ng automatic transmission fluid yun "DIALYSIS" style?
    kasi po gusto ko mapalitan lahat ng lumang ATF sa kotse ko pati yun nasa Torque converter?
    pls post here kung saan yun magaling na mechanic or shop. thanks.
    Jun 2006
    If I'm not mistaken, both Speedyfix and Autotechnika does this. I think they use a machine. It can also be done manually. Just be ready to buy around 18 liters of atf
    Had mine done at Autotechnika before.... used up 24L of ATF to completely clean the system. Sulit naman.
    The amount of ATF needed depends also on how dirty the system is.
    Apr 2010
    wow that's a lot of ATF to flush! thanks a lot guys for the help! punta na lang ako dun!
    Apr 2010
    How much did the whole process cost? (ATF and labor/service fee)
    Jul 2010
    how about the process of AT dialysis? nakakailan friends na nakapagsabi na maganda daw yung process at hindi magasto kasi normal ATF qty lang kelangan
    Nov 2006
    Had my at dialysis done today in EXALTA along nicanor roxas.
    Labor 600
    Atf top 1 dexron III..... 8 li consumed. ultrashop is cheapest at 180 per liter. Other shop 200.
    Apr 2011
    ok plz call 09072459050 or 09281904001 anung unit b ng car mo?
    Apr 2010
    Whew thanks sa thread na ito. already done it last week before trip to baguio! I decided to have it changed kay Fronte banawe.
    I met this mechanic very friendly and had tons of good advice in maintaining auto transmission.
    we flush out the old fluid (17 liters maybe because its 4 wheel drive) then binanlawan namin muna ng Dextron III yun entire transmission to flush out the residue and sludge para malinis mabuti tapos drain ulit yun Dextron III. then nilagyan na ng Type T-IV which is the correct fluid. (T-IV is expensive)
    Done it my Gen2 RAV4 4x4. sobra itim na ng AT fluid ko. gaano ka itim? more than a black talaga. sulit na sulit. done it at 3600 total cost!
    the normal drain and fill process wont do the job. this is the right way to maintain your AT life
    i recommend this shop. pwede ka rin bumili sa labas ng AT Fluid. 700 labor/dialysis machine. the people here are friendly
    Apr 2011
    Quote Originally Posted by kicks4us24 View Post
    bro.....transmission fluid ba ang pinaltan mo? o kasama na ang gear differentials front and rear? at pati narin ang transfer case?
    because 17 liters drained from your transmission is way too much.
    How many liters did your mechanic put in your transmission? (RAV 4 right?)
    ISn't T-IV fluid is same with Dexron III ATF?
    Apr 2008
    sir sakin kc almost dark brown narin ATF ko and it smells quite burned. same din ba sayo? before mo ipa dialysis have you experience slipping performance on the transmission?
    The dialysis for the Sentra done at Exalta Motors last March 3, worked. Ok na ang shifting despite having 150,000kms already. =)
    Php700 for the machine and Php2000 for 10 liters of ATF.
    The 150,000km Sentra:
    Exalta Dialysis Machine (seems to come from Korea):
    The shop across the street (N.Roxas St.) also offers the same service:
    Naalala ko pa nung brand new itong Sentra na ito. :D Ganda pa rin ng glass headlights ng B14 151.
    Good to hear the ATF dialysis worked; baka pinakulong tayo ng Tito mo kung hindi gumana. Dapat siguro gawin mas madalas yung ATF change (i.e. every 20,000kms?) given na high mileage na yung car. Si Mang Mario ganyan ginawa niya to avoid that Galant AT plague on his car; palit siya ng ATF every 10,000kms i think.
    Aug 2009
    good eveng. the name of the mechanic? name of the shop? did u bring the atf oil? or kanila na? pwde din yan sa 03 isuzu trooper 4jx1 engine? thanl u
    N. roxas near banawe po as previously posted.
    Vinj,
    Ayokong makulong. Hehehe
    Oct 2011
    Compatible ba ang Dexron III sa Toyota Type T-IV?
    Mga Boss, yung 1995 corolla a/t ko minsan pagka start ng engine, pag shift ko from
    Park to Drive minsan almost 10 secs before kumagat. pati from Drive to Reverse, but
    this is every time i start the engine. I looked at the at fluid clear pa naman sya and
    hindi amoy sunog.
    What do you guys think of the problem? These days, mabilis naman ang kagat. Minsan hindi.
    Should I Change the ATF already?
    Sa exalta motors ba pwede toyota? or pang nissan lang sila? may recommended shop ba for
    the toyota for the dialysis?
    It sometimes frustrates me. Thanks for the future replies!
    Aug 2011
    Quote Originally Posted by nice&clean View Post
    hindi amoy sunog.
    Ask yourself first chief, when was the last you've changed the ATF? Ako just to avoid these issue, as much as possible, I change ATF fluids annually. Our oldest car in the family is a Corolla AE101. Malapit na siyang mag-debut. Never kami nagkaroon ng issue sa AT dahil sa regular ATF change.
    Dec 2009
    hindi amoy sunog.
    basta alaga sa ATF change, the AT transmission will last with the car,, pag bagong atf change tapos everything is fine with the electronics tapos matagal bago umalis from N/P?R to D, baka mga solenoid or worse valve body sa internals ng AT transmission..
    kase the valve body and solenoids pumps and controls the flow of ATF fluid to generate the required torque slip...
    ^ How many kilometers/mos. ka bago magpapalit ng ATF sir miko? And what do you use/recommend?
Changing ATF Fluid completely (DIALYSIS PROCESS)
