Results 1 to 11 of 11
    my 2003 altis AT's trans has to be fixed. AT shift stick doesn't rake smoothly. may resistensiya na nakukuha sa de gulat while pressing AT shift button.
    the transmission functions and auto-shifts well naman, once the stick is in place.
    we have ruled out cable and AT stick assembly causes.
    a shop in sucat, DnR (sounds ominous to doctors!), was recommended. shop says they will require car to be left for three days. but i am wary of the three days, as "many things can happen to the car while in there".
    banawe guys say they do it in one day, "while-you-loiter".
    either choice estimates the same cost (20-25K).
    recommendations?
    recommendations?
    Oks dyan sa DnR Fast Auto Repair Shop. I used to bring our cars there when we had a number of out-of-warranty Hondas. Donnie, the owner, is easy to talk to and he will be honest in his assessment. AT trannies are their specialty. They will let you know if the car can be done in a day or two. They also have a number of tow trucks including a flatbed one for AT cars.
    Lagi puno dyan kaya dapat maaga ka kung papagawa ka dyan.
    thank you.
    Aug 2017
    recommendations?
    Since cost is the same, I'll go for the shop doc. The warranty they'll give you will give you peace of mind.
    Aug 2017
    recommendations?
    Since cost is the same, I'll go for the shop doc. The warranty they'll give you = peace of mind.
    Quote Originally Posted by SidCoronel View Post
    i agree. medyo out of the way lang...
    Jan 2008
    recommendations?
    Baka need lang lubricate yung sa transmission lever.. baka may sirang bushing dun sa lever
    na-kita na po earlier. we were able to conclude that the AT shift assembly and cable (newly replaced) are fine.
    i-su-supi ko na sa shop.
    update ko kayo.
    recommendations?
    update.
    i got the car already from DnR. AT stick rakes fine now. it drives more pleasurably again!
    mechanic says the trans linkage inside was broken, whatever that means.
    Jun 2005
    update.
    So how much did it cost? 25k?
    Sent from my MI MAX 2 using Tapatalk
    Quote Originally Posted by sirkosero View Post
    yup.
    labor was 6K. the rest was for the brake band, the AT repair kit, the filter, and the ATF.
    i was happy. hindi na ako tumawad.
altis AT repair
