Results 1 to 9 of 9
September 18th, 2005 05:26 AM #1
Sometimes when i turn on my a/c, i hear a sound identical to that of a worn out clutch (rough shifting sound) or when you shift into gears without stepping on the clutch all the way down accidentally...a mechanic told me that problem might be with the aircon clutch? i don't hear it when the a/c turns off then back on automatically, only when i first turn it on, at least once each time i use my car.
How true could this be? i didn't know a/c's have clutch...
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 18th, 2005 01:09 PM #2a/c's have clutches. this is what engages/disengages the compressor they get worn and will have excess play when the clutch is ubus na.
September 18th, 2005 01:19 PM #3
thanks speedyfix! you have any rough estimate how much would it cost to replace? and is it something urgent or should i just wait till i hear the sound everytime i turn it on? lastly, would this service be available at my suking a/c shop? thanks again!
- Nov 2003
- 3,849
September 18th, 2005 02:34 PM #4price will depend on the car but you'll have to ask your ac shop how much it will cost kasi baba ng compressor yan to replace it. then they will clean the system narin if i'm not mistaken.
September 18th, 2005 02:53 PM #5
mura lang yan, and if kapos talaga budget there are even overhauled/rewinded clutches available for half the price. pwede pa yan gawin na hindi ibaba ang aircon compressor. kahit ako kaya ko yan, need mo lang ng internal circlip plers to remove the clutch from the aircon compressor shaft. medyo mahirap lang nga kasi masikip ang space at di kita directly yung circlip. pero pag may mirror at flashlight kita naman yun e. remove the pulley from the clutch, then remove the circlip that holds the clutch to the shaft, then use a puller to slide it from the shaft. yun lang, so simple! car aircon shops will tell you they need to remove the compressor completely kasi they want you to spend more money for replacement of filter-dryer, vacuuming and refrigerant recharging.
- Sep 2005
- 103
September 19th, 2005 09:19 AM #6Beetols,
kung gusto mo makatipid pag pinagawa mo yan, Go to Mang Mario. kilala yan ng mga tsikoteers dito. kahit ako nasubukan ko na ang galing at mura ng singil ni Mang Mario.
the best aircon shop for me! :D
September 19th, 2005 12:38 PM #7
1200 charge sa akin last year ni Mang Mario. pinalitan yung clutch ko with a new one. all in na yun: labor, R134a refill, cleaning.. binaba nga yung compressor.
September 21st, 2005 10:42 AM #8
thanks guys! yeah ive read all threads regarding mang mario's service...looks like im gonna need to come to him one of these days. agahan ko nalang nga cguro. I'll try canvassing around as well...mejo malayo ren kse at mukhang pila balde!
*yebo: very informative! thanks!
- Sep 2010
- 3
September 20th, 2010 01:40 PM #9
