yes sir, you're right. i have located the drain plug and done replacing the atf myself...you can remove the plug with the handle of a 3/8" ratchet wrench (not 1/2"). my city has no removable oil pan. though there's an opening for the torque converter. thanks to all
sir pinalitan mo rin ba yung crush washer doon sa drain bolt??
high idle RPM at engine start
