Results 1 to 5 of 5
- Jan 2012
- 4
August 16th, 2013 12:53 PM #1Mga boss,
I have an opel tigra, converted ung engine to sentra GA15, originally manual ung tranny ng engine, recently converted to AT.
nang makuha namin ung car from the shop na gumawa ng conversion, napansin namin na walang D. from neut S na agad.
at first ang problema lang is mis aligned lang shift stick at matagal mag upshift. kailangan umabot sa 3.5k to 4k ang rpm bago mag upshift. Pagnagslowdown naman di ramdam ang down shift.
tapos after a while, pag mainit na ang engine (and I suppose the tranny din), hirap na pumasok ung reverse. kailangan pang bumalik sa park bago papasok reverse.
we tried replacing the ATF twice na. hindi parin nag change ung upshift at mahirap parin pumasok ang reverse pag medyo mainit na ang engine.
we also tried cleaning the filter of the tranny pero wala paring pagbabago.
tapos recently, nawala na ung reverse. kahit cold or hot ayaw na pumasok ung reverse.
I hope na matulungan nyo ako mga boss.
Tnx in advance.
August 16th, 2013 01:07 PM #2
Why "clean" the filter? It's disposable AFAIK. Sa Benz, pag ganyan ang symptoms ... most likely its a clogged tranny filter.
- Jan 2012
- 4
August 16th, 2013 05:32 PM #3pasensya na boss... kung clean filter ang first aid... yun kasi nabasa ko sa net e.
- Oct 2009
- 2,271
August 18th, 2013 09:37 AM #5
marami sa nissan strainer ang gamit kaya ok lang linisan kung hindi masyado marumi and barado screen. AFAIK 2 klase ang ginamit na trans; hydraulic and electronic. since transplant ito, pag electronic ginamit ay hindi na gagana ng matino ang trans. kung hydraulic naman dapat maayos na mabuti ang throttle control, pero sa kaso mo more likely the trans is shot and need na irebuild
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
