Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Car: Suzuki Swift 1.2L AT 2015
    Problem:
    Unable to press the shifter button to change gear, unless AC is OFF
    Brief history:
    issue started after non casa body repair was done (rear collision)
    apparently, the shop was not able to seal the 3rd brake light properly, hence shorting occured.
    after replacing the fuse, shifter worked fine for a day. but since it the replacements were popping as soon as it was installed (next day), i decided on installing a higher rated fuse temporarily (10A to 20A)*i know, wrong move*; just up until the next day where i have a time to have it fixed.
    after electrician (non-casa) replaced the brake switch, and rewired the 3rd brake light (grounded due to water intrusion);
    brake switch is OK (but was still replaced)
    everything works normally, except that i have to make sure AC is OFF; if AC is ON, there's no way for me to shift from PARK (button is hard to press).
    NOW even if the AC is OFF, unless i UNLOCK the Shift LOCK; there is no way for me to move it from PARK
    I still have the original, working brake switch; should i return it?
    car is with my other boss, and downtime (leaving in casa for diagnostic, is not an optio)
    no CEL btw
    sounds like the problem is "cross-wire syndrome", probably at the fusebox area...
    try this... remove one fuse at a time, and see if the problem "improves" each time one is removed.
    i know... non-logical.. but the procedure is free.
    youre correct bro, pero ginawa na yan nung electician with me. doubtful ako nun tinutulungan ko sya, pero um oo ako, kasi gusto nga daw nya ma isolate.
    May 2011
    Check for power at the O/B orange/black wire at the brake light switch. If there is power, check if power goes through G/B green black wire at the brake switch with the brake pedal pressed. This is done with the transaxle shifter is in the P position. Then check for power at the shift interlock solenoid.
    Quote Originally Posted by mina_nuka View Post
    i like this guy!
    ...knows his stuff.
    Salamat mina
    Pag pinabasa ko ba ito sa reys electrical na tech, ma gets kaya nila ito agad?
    Sent from my SM-C900F using Tapatalk
    Jan 2009
    You can skip the first test. Just check that the brake lights are working when you step on the brakes. That will confirm that the brake light circuit is energized and the brake switch is working.
    May 2011
    There are two brake switches.
    One
    For the brake lights
    Another for the shift lock release on this car.
    Some cars have two,
    one for the brake lights
    The other
    for PCM input to cancel the torque converter clutch.
    Jan 2009
    One
    Some cars have two,
    The other
    I beg to differ. This is based on our 2013 Swift A/T 1.4. It only has one (1) brake pedal switch with two wires (white part near the center of the pic below).
    The brake pedal position switch typically goes to the Swift's body control module (BCM). The controller then provides the logic and drive to operate the brake lights and the A/T inter-lock solenoid. The switch does not directly drive the brake lights nor the solenoid, the controller does.
    If the brake switch is not working or if that part of the circuit is dead, it won't be able to trigger both the brake lamps and A/T interlock.
    Further, the fact that the A/C has to be off to be able to shift, also seems to suggest that the BCM was damaged. And as it turns out, among other things, the BCM also controls the A/C.
    Where I'm getting to is that, by shorting the 3rd brake lamp, the mechanic could've damaged the controller. And with the TS using a 20A fuse (in a 10A circuit), I think it made matters worse. I am hoping that I'm wrong because I was originally going to say that since this was a body work, the mechanic could've just left out a ground anchor point near where the damage was.
    NOTE: Edited for additional information and grammar correction.
    Mga bros salamat sa reply
    Ito pala yun orig brake switch (hope this helps you guys help me identify my trouble)
    Do you think permanent unlock nalang sa shift lock ang solution? Una kasi as long as AC is off, ok lang eh
    Ngayon maski off ang AC, ayaw talaga
    Jan 2008
    Looks like an ordinary brake switch... have you tried disconnecting the 3rd brake lamp? Baka may wire na exposed or naipit shorting the circuit when it was repaired.. also check voltage at actuator
    San yun actuator bro?
    Btw 3rd brake light is fine, may isang busted bulb lang
    Ok lang kaya lagyan ko nalang yun shift lock ipitan ko nalang?
    Jan 2008
    Yung actuator ng shift lock. You can hear it click when you press the brake.. assuming na electric yung shift lock.. sa picanto kasi cable type
    magkaka problema kaya kung ipitan nalang shift lock, habang intay parts replacement / repair?
    Jan 2008
    Pwede naman.. just be mindful to press brake when shifting.. yan nga daw cause ng sua ng montero kasi walang shift lock
    Thanks
    Sobrang hassle kasi
    Magkano kaya kung bcm ang pagawa or yun mga na mention dito?
    Jan 2009
    Thanks
    Sobrang hassle kasi
    Sayang lang na bakit hindi sa casa pinaayos in the first place? The car is 2 y/o and usually, comprehensive insurance allows you to have your car repaired at the dealer for the first 3 to 5 years.
    Anyway, it won't be cheap to have the BCM replaced. I'm not even sure it can be repaired. The easy way out is to disable the A/T lock-out, but it's possible that the BCM has already developed other issues. The BCM controls almost everything electrical and electronic (horn, interior and exterior lights, central lock, factory alarm, wipers, A/C, etc.... except for anything to do with engine and powertrain management (that's the ECM/PCM's job).
    The BCM is usually integrated with the fuse, junction, and relay box, located under the dashboard, and typically replaced as a whole. It will look something like this:
    [img]https://c.76.my/Malaysia/suzuki-swift-fuse-box-junction-36780-72k11-36770-72k11-senhuiauto-1307-16-senhuiauto*1.jpg[/img]
    i did not notice, that the car is a 2015...
    so, the car is 2 years old from new, and then develops this kind of a problem, and owner opts to have it repaired outside the casa?!!
    Jan 2009
    The problem appears to have been caused by the talyer mechanic where the vehicle was repaired for a rear-end collision. I'm just surprised that it wasn't fixed at the dealer. I always insist on my insurance to have all covered work done by the dealer. The only time my car got in a talyer was when it got rear-ended on its 6th year. Say what you want with casa and their exorbitant rates, they still generally do a better job than most talyers. And my insurance is paying anyway.
    well, we all had our appointment with "i thought it was a good idea at that time" syndrome...
Suzuki Swift AT/Won't shift from Park unless AC is OFF
