Page 2 of 2 FirstFirst 12
Results 21 to 40 of 43
    i did not notice, that the car is a 2015...
    so, the car is 2 years old from new, and then develops this kind of a problem, and owner opts to have it repaired outside the casa?!!
    Jan 2009
    The problem appears to have been caused by the talyer mechanic where the vehicle was repaired for a rear-end collision. I'm just surprised that it wasn't fixed at the dealer. I always insist on my insurance to have all covered work done by the dealer. The only time my car got in a talyer was when it got rear-ended on its 6th year. Say what you want with casa and their exorbitant rates, they still generally do a better job than most talyers. And my insurance is paying anyway.
    well, we all had our appointment with "i thought it was a good idea at that time" syndrome...
    tapos na bro, 3rd party claim kasi sa insurance nung truck na nakabangga sakin. di ko naman alam na ganito kalalabasan, dahil nung nabangga ako sa likod, walang tama yung 3rd brake light and OK naman wiring nun left and right rear lights assembly. next time pag may bago akong kotse ulit, di ko na ipapasok sa ibang insurance; FYI standard insurance gamit nung nakabangga sakin.
    *oj88
    bro makikita ba ito sa obd2 scanner kahit walang CEL?
    Jan 2009
    *oj88
    Baka hinde. Usually, yung mga error codes na nahuhugot ng OBD2 scanner pertains to the ECM. At least sa Honda ganun.
    Honda calls their BCM the MICU, and they have a specific method of extracting MICU errors. The following is the video I made about it several years ago sa then Civic FD ko. If you can somehow search for your car's repair manual, there should be a procedure to do the same on your Swift.
    The "DTC" (Diagnostic Trouble Code) here pertains only to MICU/BCM errors. This method won't show ECM/PCM DTCs.
    *oj88
    i agree.
    let's move on.
    Jun 2005
    I think this was my brother's old city.
    Car wont start. Checked everything. Problem was a simple busted brake fuse.
    Quote Originally Posted by sirkosero View Post
    Yan yun initial na sira sakin bro. Kaso pinilit ko taasan rating ng fuse, putok din
    Sent from my SM-C900F using Tapatalk
    update:
    nakaka shift with fan/AC ON, pero dapat 1 lang fan; anything higher di na sya papayag mag pa click to change gears.
    i know medyo useless since bypassed na yung brake, nilagyan ko narin fuse 10A.
    bro oj88, pwede ako mag post ng link? di ko makita kung san ko dapat i short eh. thanks!
    Jan 2009
    update:
    The video I've shown works on the Honda Civic. It's just an example. Malamang ibang method sa Swift. Try searching for the repair or shop manual for the Swift. These types of info is usually found there.
    Jan 2011
    hope the car runs fine now. this is the reason why I'm in tsikot. daming gurus. daming matutunan dito.
    Sent from my SM-G610Y using Tapatalk
Suzuki Swift AT/Won't shift from Park unless AC is OFF
