Results 21 to 30 of 43
September 11th, 2017 01:59 AM #21
tapos na bro, 3rd party claim kasi sa insurance nung truck na nakabangga sakin. di ko naman alam na ganito kalalabasan, dahil nung nabangga ako sa likod, walang tama yung 3rd brake light and OK naman wiring nun left and right rear lights assembly. next time pag may bago akong kotse ulit, di ko na ipapasok sa ibang insurance; FYI standard insurance gamit nung nakabangga sakin.
*oj88
bro makikita ba ito sa obd2 scanner kahit walang CEL?
September 11th, 2017 07:33 AM #22
Baka hinde. Usually, yung mga error codes na nahuhugot ng OBD2 scanner pertains to the ECM. At least sa Honda ganun.
Honda calls their BCM the MICU, and they have a specific method of extracting MICU errors. The following is the video I made about it several years ago sa then Civic FD ko. If you can somehow search for your car's repair manual, there should be a procedure to do the same on your Swift.
The "DTC" (Diagnostic Trouble Code) here pertains only to MICU/BCM errors. This method won't show ECM/PCM DTCs.
September 11th, 2017 08:29 AM #23
- 52,698
- Jun 2005
- 3,769
September 11th, 2017 01:29 PM #25I think this was my brother's old city.
Car wont start. Checked everything. Problem was a simple busted brake fuse.
September 11th, 2017 02:30 PM #26
September 12th, 2017 07:44 AM #27
update:
nakaka shift with fan/AC ON, pero dapat 1 lang fan; anything higher di na sya papayag mag pa click to change gears.
i know medyo useless since bypassed na yung brake, nilagyan ko narin fuse 10A.
bro oj88, pwede ako mag post ng link? di ko makita kung san ko dapat i short eh. thanks!
September 12th, 2017 08:44 AM #28
- Sep 2017
- 8
September 16th, 2017 09:40 PM #29did you fix this issue?
did you fix this issue? ano nangyari
September 17th, 2017 03:23 AM #30
Cabin Air Filtre Carbon activated, interchangeable with 27277-4JA0A/B P190 only. Almost P3k ito...
Nissan Navara NP300
