Results 1 to 5 of 5
    6 years old. how many times have you changed the atf? jerking normally occurs if you use the wrong atf
    Nov 2017
    ODO is currently at 70k. It was first changed at 50k and then it was replaced again when we had the shift solenoid B replaced as they replaced the ATF alongside the solenoid.
    May I know what ATF you can recommend for our starex?
2011 Starex CVX VGT transmission problem
