Results 1 to 5 of 5
- Nov 2017
- 24
November 4th, 2017 05:56 PM #1hi guys, our starex wasn't shifting from 1st gear anymore so we had our transmission "shift solenoid B" replaced (which was shown in the OBD scanner) and then after that it now shifts up but is jerking when shifting from netural to drive and also when upshifting as well as downshifting. Sometimes, it also gets stuck on 4th gear even on full stop it won't go back to 1st gear. Any idea where I should bring it and what to check? thanks
there is also a delay when shifting from reverse to drive and vice versa.
November 4th, 2017 05:57 PM #2
6 years old. how many times have you changed the atf? jerking normally occurs if you use the wrong atf
- Nov 2017
- 24
November 4th, 2017 06:05 PM #3
November 4th, 2017 06:46 PM #4
what atf was used when you repaired the transmission?
fully synthetic "multi atfs"
motul
mag1
mitasu "premium 100%"
synthetic "mutli atfs"
mitasu synth blend
royal purple
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; November 4th, 2017 at 06:57 PM.
November 8th, 2017 11:32 PM #5
ano ho ba ang exact trouble code at nagpalit ng shift solenoid (format ng dtc ay P07xx). nag perform ba ng stall test s drive and reverse? yung delay ba frm park to reverse and from neutral to drive ay more than 2secs? if so, maari may leaks na sa mga seals or mababa line pressure.
Daming issue ng SU7:grin:
Xiaomi E-Car
