Page 1 of 4 1234 LastLast
Results 1 to 20 of 81
    SMy Innova is with an automatic transmission. This is my dilemma every time mag-traffic sa city and ang ride is usad pagong.... what should I do .... Do I have to maintain at "D" while stepping the brake and release the break to move a little forward? Or could I put it at N with the handbreak then shift back to D and release the handbreak to move forward a little? Stepping on the break for a long period at time hurt my right knee/leg... Ilang estimated seconds or minutes ba before considering placing it at N? Hope someone can enlighten me on this....
    in crawling traffic, i keep it on D, and press on the brake pedal, releasing it from time to time, to ease the car forward.
    when it is total standstill, for longer periods like a minute at least, i put it on N.
    kanya-kanyang style po yan.
    there are arguments for and against, but my personal bottom line is, "the degree of wear and tear is probably not worth the effort at arguing".
    keep proper distance. press brake pedal slowly and release once moving. the tcm and ecu knows what to do naman.
    Just keep it in D and press and release the brake pedal as necessary. Do not play with it (shifting from D to N to D) as that will prematurely wear out the transmission friction bands and solenoids. It is an automatic transmission controlled by a computer so leaving it alone works best all the time.
    Aug 2017
    Agreed Doc!
    Not placing the gear in N downsides:
    1) Wears your knee and patience
    2) Burns ATF, especially DCTs
    3) Wears your brake pads.
    I have 16 Grab cars, 5 ATs (2 DCTs), reason I know.
    Jan 2016
    There's no right or wrong, just do kung saan ka comfortable.
    I don't think doing either will matter much to a brand new car. If you have an older car and plan to keep it for a few hundred thousand km maybe it might wear out earlier but you have to consider your comfort and well being as well.
    Ayan na ang suma nyan, kung 10 years or 200k kms mo lang naman hahawakan ang car mo, i don't think it will fail just yet.
    Mine, i put the gear on N if on heavy traffic and shift to D once its moving... same with traffic light if more than 60secs i put it on N... i dont know if its the right way though... hahaha
    Nov 2017
    I do the same. That's what our mechanic told me to avoid premature wear and tear in the transmission.
    Forget the existence of your left foot to avoid SUA and...
    Don't forget to use the right foot to step on the brakes when you need to decelerate/stop the car.
    Jun 2013
    nasanay nadin ako na kapag stand still traffic or red sa traffic lighr nag neutral nalang ako..
    pag moving trapik naman pinapauna ko ng konti yung nasa harap para di masyado na kaka ngawit sa paa pag brake...
    Sep 2019
    ako ginagawa ko madalas "D" lng at handbreak... pero kapag napagod na ang paa ko saka lang ako ng "N" lalo na matraffic talaga.
    Feb 2019
    I'm not sure if this is the right thread for this question, but anyway, please enlighten me on this: Yung parking area namin dito is naka-elevate so pag nagpapark kami, we have to control the car properly kasi uphill yung pagpasok. May instances na backing ako magpark, then one time habang nagrereverse ako sa uphill, bigla kong nabitawan yung brake which caused the car to move forward. My question is, is that okay? Meron bang possibility na ma-damage yung transmission ng oto ko or what so ever? If that so, any advise or meron bang proper way to do that and vice versa? Advisable din po bang tapakan ang brake while pressing gas pedal then slightly release the brake pedal to move? Thanks in advance!
    Aug 2017
    Quote Originally Posted by jnsk View Post
    Instead of using the brake pedal, use the hand brake
    no harm will come to the transmission, or the engine, po.
    transmission slip is normal in AT or CVT cars.
    you'll run out of right feet, if you press on the gas pedal and the brake pedal at the same time. it just ain't practical. i agree with sid: use the handbrake.
    and you will eventually notice, using the handbrake in instances like this, is easier if the handbrake is adjusted according to spec.
    Dec 2009
    Kung hirap na ang legs mo after pressing your brake eh di ipahinga mo na by using N and handbrake
    There is what you call muscle fatigue and it varies with every individual. When those legs feel weary pressing the brake pedal its only logical to rest it by engaging the N gear and handbrake..its that simple
    Sent from my SM-G532G using Tapatalk
    Sep 2013
    Sanayan Lang Yan TS, ilagay mo sa D at apak brake. Dika pala pwde sa mga heavy traffic Yung tipong kalahating araw usad pagong. Tip lang wag ka pupunta NG tagaytay kapag pasko, 7hours aabutin mo sa traffic pababa lang NG santa rosa
    Apr 2012
    Quote Originally Posted by NiCe2KnowU View Post
    Experienced that a week ago Sunday. Galing ako ng farm hills. Umakayat pa akl ng tagaytay para mag Aguinaldo highway at lumusot pa Carmona.
    Sent from my SM-J730G using Tapatalk
    Did the same yesterday. Went up to Tagaytay thru Santa Rosa and saw the traffic going down was very slow. I went back thru Silang-Carmona.
How to properly drive an automatic transmission car during traffic?
