Results 1 to 5 of 5
    mga sir ask ko lang po, pag nag shift po kasi ako sa 1st gear yung engine nag vi-vibrate with some knocking sounds na parang mamamatay makina, so shift ako 2nd gear ok naman hanggang fifth, 1st gear lang talaga. suspect ko na po na sa tranny ang problema pero di ko lang po alam kung ano talaga dun ang may kelangan palitan or may problem. is it the clutch or pressure plate, etc.
    ano po kaya sa tingin niyo ang problem? TIA
    Have your clutch checked by a mechanic...
    __________________
    bigbigcar.com Review: Chery QQ3 1.1 MT
    Small car, big ambitions: The Chery QQ is the vanguard of the Chinese invasion.
    Nov 2003
    engine supports yung likely na problem but you'll need to have them checked in person by a mechanic.
    I bet its either a dragging clutch or a sliding clutch. P baba mo na tranny mo, palit clutch, pressure plate and release bearing.
    Kung engine mount yan pag nag low gear ka mula sa mataas, mararamdaman mo vibration at hindi kaya patayin ang makina ng engine mount problem.
    Nov 2006
    try the t/a mount first.
1st gear, engine vibrates
